Anyone else have this anoying rattle? Mine only rattles sometimes, and I have heard that it is part of the heat sheild or something. Anyone fixed this before?
Hi 93bigbronco..you should get under the vehicle check anything that may be loose, or in rare cases, the cat conv. can rattle from inside...this means replacement.
I just found a rattle a few days ago. At high rpm's
it sounded like I was running through an inch of water. It turned out to be a tube coming from the engine to the converter, just mig-ed it back on and it sounds like a new one.
Good luck, John
