oil leak
Old May 2, 2007 | 08:26 PM
fordboy2's Avatar
fordboy2
oil leak
There is a sensor in the driver side valve cover near the front, that I think may be where my oil leak is coming from. What is this sensor for, and has anyone ever seen it leak from here? I originally thought my hpop was leaking but after cleaning everything up and runnning it for a couple of days the hpop appears to be really clean and dry. I was just looking for input on this as i think I may look into checking on this more tommorow when I have time.
Old May 2, 2007 | 08:43 PM
Uzumati's Avatar
Uzumati
That is the ICP sensor it read the pressure in the HP oil rails so the PCM knows how to command the IPR.
Old May 2, 2007 | 08:59 PM
fordboy2's Avatar
fordboy2
is there an o-ring or seal on it that could be allowing oil to blow out?
Old May 2, 2007 | 09:19 PM
fordboy2's Avatar
fordboy2
by the way what does ICP and IPR stand for?
Old May 2, 2007 | 09:22 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
There is an o-ring that seals it to the head. By the way it is not in the valve cover, it is in the cylinder head's high-pressure oil rail. ICP means Injection control pressure, the pressure of the oil in the rail that is the mechanical force used to pressurize fuel to injection pressure. The IPR is the Injection Pressure Regulator and it regulates this highly pressurized oil from 500psi at idle to 3000psi at WOT.
Old May 3, 2007 | 08:43 AM
fordboy2's Avatar
fordboy2
strokin, is there anything special about the o-ring, can I get one from one of the sponsers here on the site? How often does it leak from here? The hpop is totaly dry so I find it hard to believe thats where it is leaking as the mechanic I had look at it said. I really appreciate the help.
Old May 4, 2007 | 08:59 PM
fordboy2's Avatar
fordboy2
does anyone know where I can get the o-ring? I am going to look into it in the next couple of days and will proably replace the oring anyways.
Rhager
May 8, 2013 09:15 AM
cherrob123
Nov 2, 2011 11:59 AM
Pete in Maine
Oct 4, 2011 10:42 PM
matt71
Jul 9, 2008 08:52 AM
Spirit615
May 16, 2006 04:22 PM
