1978 - 1996 Big Bronco
SROD Rebuild
Old May 10, 2001 | 07:30 AM
ronbo862's Avatar
ronbo862
SROD Rebuild
Folks, I think someone pulled a fast one on me (say it isnt so!). I purchased an 84 Bronco with a 300 and 4sp OD which I thought nothing of until I went to change the clutch. It seems this tranny is the SROD which is'nt normally found in 4X4 vehicles. I have had nothing but trouble trying to locate parts for the thing. Anyhow, after changing out thew clutch I find out the input shaft bearing is bad. I called Ford to try and research parts, what a fiasco! What we finally end up with is two part numbers, one for a bearing that is press fit and one that is slip fit. So which is it? Is there anyway short of tearing it down to find out? I'd like to order the part and have it on hand for when I pull the tranny again. He could'nt find the bearing on the west coast so it will be sometime before it gets here. I tried the local boneyards but found nothing, one place told me the last one they sold went for $700.00. I couldnt stop laughing. Any help will be appreciated, thanks!
Ron
Old May 10, 2001 | 12:08 PM
bigfordman70's Avatar
bigfordman70
SROD Rebuild
That can't be the factory tranny, can it? the only place I've ever seen that single rail POS is behind a 2.3 in a mustang.
I've got a friend with an 88 F-150 4x4. It's got the 300 and a 5-speed, looks like a T-5, but I'm not sure. I wouldn't think it would be too complicated a swap if you could find one. All I know is I'd scrap the SROD. There is a reason Ford only used them for three years.
BFM
Old May 10, 2001 | 02:14 PM
ronbo862's Avatar
ronbo862
SROD Rebuild
Roger, that is from the factory. Everyone says the same thing but when I went to Ford they confirmed that the Bronco came with them. How they determined who got screwed I don't know. I guess it pays to do a little research before buying a vehicle I'd swap it if I new what would fit in there. I dont want to be changing driveshafts though. Thanks for the reply
Ron
Old May 10, 2001 | 04:59 PM
buckeye's Avatar
buckeye
SROD Rebuild
Paid 4 and Love it
25
May 29, 2017 01:08 PM
Pitweiller13
Dec 10, 2015 04:12 PM
Four.on.the.floor
Arkansas Chapter
Oct 18, 2014 04:18 AM
Cougar54
Aug 13, 2014 11:57 PM
newr
1983 - 2012 Ranger & B-Series
Aug 4, 2014 02:25 PM
