I just want to confirm that the 6.9L has the same bellhousing pattern as the 460 "385" engine, mainly want to verify that a 460 can be bolted to a C6 or T-18/19 formerly behind a 6.9L. Thanks!
no the bell housing bolts directly to block. check with advance adapters they might have an adapter remember that gas & diesel zf5's have different ratio's.
... isn't there an adapter that bolts on between the engineand bellhousing?...
Yes, there is an adapter between the engine and bellhousing. However, the engine pattern is not a Ford pattern, it is the IHC MV pattern. A small adapter mounts to this which matches the Ford 'diesel' bellhousing pattern.
Thanks for the help so far, but my basic question is still not answered: What is the pattern on the tranny ... is it the 385 (429/460) or something else? Many thanks.
I belive it is BUTTTTT le me double check.... I know the 6.9 in a bus and a 6.9 in a regular truck has a diffent pattern... differnt adapter plates ... le me look this week end I have a 6.9 in my garage and a 460 in there also I'll unbolt the 6.9 bellhousing and see if it will bolt on the the 460... now if your truck had a stick just unbolt the bellhousing from the tranny and put the one from the 460 on there.. remember a 400m is the same bolt pattern as a 460 (doing a 400m to 460 swap on my truck (avatar) ... my buddy bought a diesel truck (deisel had a rod through the block) he put a 351 w in there but with the diesel tranny it seemed to be to high geared ... taking off in first was like trying to start in second... some people say the diesel tranny's are geared differnt thus I don't know and can't prove..
Thanks for the help so far, but my basic question is still not answered: ...
... mainly want to verify that a 460 can be bolted to a C6 or T-18/19 formerly behind a 6.9L. Thanks!
To answer your original verification(quoted above): No and yes. No, a 460 cannot be bolted to a C6 formerly behind a 6.9L without adapters. Yes, a 460 can be bolted to a T18/19 formerly behind a 6.9L without adapters.
Because the bellhousing is seperate on the T18/19 transmissions(gas or diesel) and the transmission mount pattern is not different between the two in Ford applications, a T18/19 transmission can be swapped between diesel and gasoline powered apps, using the appropriate bellhousing for the engine.
A C6 that was behind a 6.9/7.3 IDI will not bolt behind any gasoline engine without using adapters.
Yes, the 6.9 in a bus uses the SAE #2 flywheel housing with no adapter between this housing and the engine block.
The bellhousing that mounts onto a Ford spec 6.9 IDI will not bolt directly onto any engine(I don't know about 7.3 PS). The pattern on the block of the 6.9/7.3 IDI is the same as IHC MV pattern. The adapter used between the engine block and bellhousing on a Ford spec 6.9/7.3 IDI will only bolt to the IHC MV engines and the 6.9/7.3 IDI. It will not bolt to any non-IHC gasoline engines.
The T19s used in the diesels are all the close ratio version. In gassers, both the close and wide versions were available. The 'granny' gear version is the wide ratio.
Is it really the bell housing bolt patterns for the diesel and gasser C6s that are different, or is it just the ADAPTER plates that are different?
In other words, can't you just swap the adapter plate from the gasser C6 onto the diesel C6 and then be able to bolt the whole thing onto the 460?
Somehow it just doesn't make sense to me that they would have two completely different castings for the C6 tranny housings - which is what it would take since the bell housing and the tranny case are all cast as one unit. It just seems to me like it would have made more sense to use the same casting for the case (including the bell housing) and use different adapter plates to mate it to different engines......
