Stronger 9 inch
Old May 1, 2007 | 09:48 PM
mudslingur's Avatar
mudslingur
Stronger 9 inch
I have a 9inch on my 77 Ford 150 4x4.I started using my truck more often since I rebuilt it and thinking about starting to haul hay again with it.The trailer comes out to about 5,000 pounds,and i usually go about 60 miles max.Since the last time i pulled my trailer i've add 35's and a little more power to the 351 over stock.im pretty sure the axle can hold up,but im considering beefing it up a little.what kinda mods can i do to the axle to strengthen it up.Oh yeah ill also be mud boggin alot so thats another concern of mine.
Thanks
Old May 1, 2007 | 10:33 PM
79f150toy's Avatar
79f150toy
you should consider your axle spline/ diameter...if it is 28 spline, then you could swap over to a 31 spline axle....much stronger....plus there are housing braces available that you weld on to strengthen the housing...theyre around 60-80 buckaroos....plus, you can change the gear ratio to compensate for the large tires....4.11s would be suitable....just make sure you purchase a quality ring and pinion....additionally, a locker would be good while your at it...
Old May 3, 2007 | 01:44 AM
WarWagon's Avatar
WarWagon
I agree although I would opt for a bolt on brace. Too much welding on the housing and it will warp. When I have narrowed and braced housing, the last thing I do is weld on the bearing ends with the jig in place. You would be surprised how much the housing warps when you ad a brace.
Timbo1985F150
1983 - 2012 Ranger & B-Series
Aug 31, 2009 04:10 PM
hogworkzinc
Offroad & 4x4
May 17, 2009 11:11 PM
gsg1970
Mar 14, 2007 04:19 PM
randy332
Mar 8, 2007 06:47 AM
econolinedriver
1997 - 2003 F150
Feb 17, 2007 07:58 AM
