What tanks will work?
Old May 1, 2007 | 07:31 PM
cghstrojan08's Avatar
cghstrojan08
I have an 82 f250 with dual fuel tanks. What fuel tanks will interchange with it. I know there is a 80-86 f150 short bed with dual tanks. Will it fit my truck? I got a long bed though. Will the regular front tank from a long bed truck fit my front tank? Will any other year of truck interchange?
Old May 1, 2007 | 08:01 PM
Redneck1465's Avatar
Redneck1465
The long bed front tank will not swap with the short bed front tank. I am not to sure about the back tank.
Old May 2, 2007 | 05:46 PM
cghstrojan08
Does anyone else know what tanks will interchange with it? How about the back tank? Could I use it off of a short bed f150?
Old May 2, 2007 | 05:57 PM
Redneck1465
If I were you I would just go out and get a new tank. For the $70-100 its not worth the headache of a used tank.
Old May 2, 2007 | 06:09 PM
cghstrojan08
Can't afford it. I will try to fix the old tanks first then go from there.
Old May 3, 2007 | 06:38 AM
GlennFordx4's Avatar
GlennFordx4
I think the short bed front tank is 16 gal and is to short to fit a fullsize bed.the rear tank should be the same but some tanks used different size holes for the sender and pick up tubes.you can put a bronco tank in the rear also if you can get all the mounting brackets and hardware,I think they were 30+ gal tanks.I agree you should just put a new tank in then go thru all the trouble of pulling out the old tank,with all the problems ford has with leaking tanks you don't know what you are going to get.
Old May 3, 2007 | 08:14 AM
jason433's Avatar
jason433
my short bed f150 has a 17 gallon tank
Old May 3, 2007 | 09:33 AM
Franklin2's Avatar
Franklin2
These trucks are famous for the top of the tank rusting out were it lays up against the crossmember. You will be lucky to find a used tank that is in good shape. You will then have to clean the old tank out, since it's probably full of old fuel and rust, which will give you carb problems.
Old May 3, 2007 | 11:19 AM
Redneck1465
A long bed front tank is a 19 gallon tank.
Old May 6, 2007 | 05:24 PM
cghstrojan08
I went to the junk yard and got the front tank out of a f350 2wd and fit great. When I pulled the new tank, it was completely full of gas and was in perfect condition. The tank only cost me $40 and I got $30 of free clean gas. I put the new tank in and no problems. I might go back and see if I can get that bronco tank. So, all I need is the straps for that tank?
Old May 6, 2007 | 07:57 PM
yodavator's Avatar
yodavator
try lmc parts they can break down the list for what will fit your truck
Old May 7, 2007 | 06:22 AM
Wild Karrde's Avatar
Wild Karrde
Wow... 30gal of gas. I bet that was heavy!
Anyway, if you use the Bronco tank, get ALL the mounting hardware, hoses, etc. If you don't wind up using them all, then it's no biggie, but if you get it halfway in and realize you're missing something you need, that's one HUGE pain in the tailgate.
I know this from experience.
