Easy Home projects
Old May 1, 2007 | 06:09 PM
SuperSnake's Avatar
SuperSnake
Easy Home projects
Other than painting what are some easy home projects that can be done at a reasonable cost?
Old May 1, 2007 | 06:13 PM
thorseshoeing's Avatar
thorseshoeing
decadent and depraved
Do you mean like home improvement?
Tim
Old May 1, 2007 | 06:17 PM
tewferford's Avatar
tewferford
It all depends on how handy one is and what needs to be done. There is many things a person can do with a little guidance and common sense.
Oh no did I say common sense again!
Old May 1, 2007 | 06:23 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Baseboard mouldings, crown mouldings, chair rail mouldings, window and door surround mouldings, with plinth blocks at the bottoms and rosettes at the top, wainscotting, ... Of course, you'd need a compound mitre saw and a 2" brad nailer for some of it. Then some tubes of sealant, nail hole filler, joint filler, sand paper...
Then you could update the light fixtures, change the wall switches and power outlets to "Decor" style (these require copper wiring though, not designed for aluminum wire)
Bathroom faucets, kitchen faucets, ... what else did we do... sliding shower door for a bath tub was easy. Wall paper is a pain in the ****, I would not recommend it. Uh, laminate flooring was easy, but I'm hearing now that it is like the basement wall wood paneling or **** carpet of the 70's. Not that attractive any more. Haven't tried tile yet.
Lots of easy stuff. Why, are you looking to sell? Or buy?
Old May 1, 2007 | 06:24 PM
SuperSnake's Avatar
SuperSnake
Yeah the common sense is no problem.The double wide I have is in real good shape. But I would like to change a few things. Example the living room has 1/2 sheetrock and 1/2 faux paneling made from cardboard. I think it would be a good time to rip it out and re insulate the walls and put new sheetrock up along with new moulding.
While I have it all out I feel like it would be a good time to put in new electrical boxes for the outlets and light switches.
Old May 1, 2007 | 06:27 PM
SuperSnake's Avatar
SuperSnake
No not looking to sell just want to update it and make it a little more modern. It's in real good shape and if I can start making improvements it will help the value here since a Doublewide on a brick foundation here in NC is considered a home and are taxed as such.
Old May 1, 2007 | 06:30 PM
bigrigfixer
The Pacifier
Well, if you're gonna redo all the drywall, might as well get in some 3/4" copper for your plumbing. And get all new copper wiring if you don't already have it.
Old May 1, 2007 | 06:32 PM
tewferford's Avatar
tewferford
Everything you mentioned is very simple, with the exception of spackling. When you decide to start, post it and we will help you through it.
Old May 1, 2007 | 06:33 PM
lariat97's Avatar
lariat97
Build a bookcase or entertainment center for your living room. Rework the shelving in your closets. I put half of my closet rods at 40 & 80 inches from the floor & the others at 72. I run a top shelf at 80 & a second shelf at 72 on the single rod area. It adds more rod space to hang a more clothes & more shelf space too. In one long closet with 5 ft double doors,I put a adjustable shelf stack 18 inches wide & 16 inches deep in the center with double rods on one side & single on the other. Use mdf shelving & it will not cost much.
Old May 1, 2007 | 06:34 PM
SuperSnake's Avatar
SuperSnake
Those are beyond my abilities. So it's the easy stuff for me.
Old May 1, 2007 | 06:39 PM
SuperSnake's Avatar
SuperSnake
Good idea for the closets. I already have a built in bookcase that seperates the living room and kitchen. But its so cheal looking it's unreal it also hides the back of some of the kitchen cabinets. But I'm sure I can change it.
first today
18
Dec 30, 2012 10:08 AM
78bigunns
Oct 31, 2006 07:07 AM
psychlopath
16
Jan 10, 2005 12:23 PM
cigarxtc
Aug 15, 2002 11:08 PM
