Lifter replacement
Old May 1, 2007 | 01:54 PM
ErnieX's Avatar
ErnieX
Lifter replacement
I read in an older post while researching that "when a lifter is replaced, cam must be replaced also". This makes sense but the inverse would also be true that if you replace a cam, all lifters must be changed. This would tell me that you can't replace a single lifter w/o replacing the cam. If you replace the cam for a single lifter, then all lifters must be replaced.
Is this gospel or just a best practice? Do I have to pull engine, replace cam and all lifters if one lifter has gone bad?????
Thanks,
EE
95 Exp 4.0
Old May 2, 2007 | 09:32 AM
WhiteBroncoII2WD's Avatar
WhiteBroncoII2WD
I've always been told that when you replace the cam you have to replace the lifters, but you can replace all the lifters without replacing the cam.
Old May 2, 2007 | 01:08 PM
ErnieX's Avatar
ErnieX
Thanks, WB, think I'll go with that and just replace the offenders.
EE
428stang
Modular V8 (4.6L, 5.4L)
Apr 24, 2021 12:48 AM
MattMac
Jul 10, 2017 03:12 PM
billyrayf150
Feb 13, 2016 11:50 AM
MRStace84
Nov 14, 2012 08:29 PM
nnewman
Jul 4, 2010 10:13 PM
