the only tube coming out of the pan is the dipstick. passenger side near the starter. be careful messing with it cause if the large nut on the outside it stripped then bulkhead fitting inside will fall into the pan and then you need to pull the engine to fix it! bad very bad!
if its leaking at the tube there is an o-ring there. if its leaking at the pan bulkhead fitting then I have had some luck just tightening the nut with channel locks. but be carefull like I said above!
