Electronic Brake Controller Question
Old May 1, 2007 | 08:51 AM
desertford's Avatar
desertford
Does anyone know if a electronic brake controller just plugs into a open plug under dash somewhere. I have a 07 screw with towing package. Thanks
Old May 1, 2007 | 09:02 AM
Tom's Avatar
Tom
There is a wiring harness and a relay that came with your truck, probably in the glove box. It has 5(if I remember right) wires coming out of it. You splice your brake controller into this and it plugs right in under the dash. There are instructions in the bag with the harness. Takes about 5 minutes
Old May 1, 2007 | 12:10 PM
osbornk's Avatar
osbornk
I Installed a Prodigy when I got my truck. Ipaid an extra $10 to get the dedicated wiring harness that plugs right in. The plug on mine was a gray plug that comes through the firewall near the steering column. took about 15 minutes to installand adjust the controller. Bought it at Rvwholesalers.com
Old May 1, 2007 | 01:50 PM
desertford's Avatar
desertford
Thank You for the info
Old May 3, 2007 | 09:13 PM
jtonkin3's Avatar
jtonkin3
Brake control 07 150
I have a 2007 f150 4.2 withOUT the tow package. It only has a for pin connector at the rear bumper. Do I have the plug for the brake control also?
Old May 3, 2007 | 09:55 PM
rob_nc's Avatar
rob_nc
Tekonsha rebate
Tekonsha, makers of the Prodigy brake controller that is so popular on this site, is the only manufacturer that I know of that offers quick connect harnesses for their controllers. This is a plus as it prevents cutting and splicing which tends to always lead to trouble later on.
I picked up a new Prodigy today and got a form for a $20 rebate by mail from Tekonsha. The rebate is good for all Primus and Prodigy controllers and is good till August 25th 2007.
Old May 3, 2007 | 10:14 PM
jtonkin3's Avatar
jtonkin3
thanks. I just can't find any plug near the fire wall to connect the harness to.
Old May 3, 2007 | 10:58 PM
kd4crs's Avatar
kd4crs
The plug is not on the firewall, it is just behind the lower edge of the dash under the steering column. It is a grey plastic jack that aacepts the plug of the controller harness. I've had 3 other brake controllers and the Prodigy is the best.
Old May 4, 2007 | 06:33 AM
jtonkin3's Avatar
jtonkin3
Man...u r exactly right, thank you very much. I have an appointment today to have someone splice my wires. Thank you1 jamie
Old May 4, 2007 | 07:14 AM
iskybantilus's Avatar
iskybantilus
you shouldnt have to splice any wires, just plug the wires into the harness under the dash, and the harness on the back of the brake control unit.
Old May 4, 2007 | 08:12 AM
jtonkin3's Avatar
jtonkin3
thank you..I have finally found the grey adapter
