We are growing
Old May 1, 2007 | 06:23 PM
  #61
blackie96's Avatar
blackie96
Well, the stupid light came back on, but it's still the same code, so I'm in the right system. Just have to fix the right part. lol
Old May 1, 2007 | 06:30 PM
  #62
SuperSnake's Avatar
SuperSnake
EVAP again, have you checked your gas cap a loose one or one that isn't tight will cause it to show code 455.I also found out from my mechanic that if you fill up while the engine is running it will cause the code to pop up.
Are you still in school for auto mechanic's? They should have a machine that you can hook up to your evap system and send smoke through it to find leaks
Old May 1, 2007 | 07:12 PM
  #63
blackie96's Avatar
blackie96
Well, it's code 1443, which is the purge valve, but I also found something that wasn't connected, so I'm not so sure it was the actual valve. Haven't started school yet, but I've had it hooked up twice....we're friends with a mechanic.
Old May 1, 2007 | 07:15 PM
  #64
SuperSnake's Avatar
SuperSnake
My mechanic forgot to hook up my purge valve and it threw a code. Did you reset it to see if the code came back on?
Old May 1, 2007 | 07:19 PM
  #65
blackie96's Avatar
blackie96
I reset it after the hoses and it came back on. I just kinda walked away when I noticed the unhooked thing after I went and bought a new purge valve because I was upset. I'm going to make sure the other thing is hooked up good before putting on the new valve, and reset it and see if it comes back on tomorrow. Have some errands to run, so I figured it would be a good time to test it.
Old May 1, 2007 | 07:21 PM
  #66
SuperSnake's Avatar
SuperSnake
Good Idea. I bought a new IAC today and my son dropped a socket into the intake area and we are having to look for it.
Old May 1, 2007 | 07:22 PM
  #67
blackie96's Avatar
blackie96
Oh no! Any luck yet?
Old May 1, 2007 | 07:25 PM
  #68
SuperSnake's Avatar
SuperSnake
No not yet I scared to start it cause I don't know whats under the FI unit. I don't know if the socket can get into the engine.
Old May 1, 2007 | 07:29 PM
  #69
blackie96's Avatar
blackie96
Well, hopefully you'll find it, and it won't go into the engine. I have to get off of here for a few....getting kids baths taken care of and such. I'll be back on in a little while.
Old May 1, 2007 | 07:30 PM
  #70
SuperSnake's Avatar
SuperSnake
Ok TTYL have Fun.
Old May 1, 2007 | 08:23 PM
  #71
BullDog24's Avatar
BullDog24
hey cliff it wont make it to the engine but if you can find it it is a good idea
Old May 1, 2007 | 08:30 PM
  #72
SuperSnake's Avatar
SuperSnake
We can't find it. I think it rolled under the lower intake.
I been so mad I haven't had time to work on the list.
Old May 1, 2007 | 08:43 PM
  #73
BullDog24's Avatar
BullDog24
hey have you talked to mako today
Old May 1, 2007 | 08:46 PM
  #74
SuperSnake's Avatar
SuperSnake
No I haven't. I only talked to Adam a while ago I'm trying to get the Cherokee GTG going too. Have you read it? It would be a good trip for you and your fiance
Old May 1, 2007 | 10:21 PM
  #75
blackie96's Avatar
blackie96
What happened to ya last night bulldog? I hope I didn't offend you.
