2001 Ranger Keys
Old Apr 30, 2007 | 12:15 PM
kstiner's Avatar
kstiner
Red face 2001 Ranger Keys
I have a 2001 range I only have one key and would like to get a second one is there any way for me to get it without going to the dealer. I don't have the time or the patience search the forms any help thanks
Old May 1, 2007 | 06:37 AM
sorensenj's Avatar
sorensenj
It's a shame you don't have both keys as you could buy a new key on ebay and code it yourself. You need both keys to do this I believe. I'm not sure what you can do with only one key. I think a trip to the stealership might be your only option. Maybe someone else will post with a better solution.
Old May 1, 2007 | 07:58 AM
pawpaw's Avatar
pawpaw
Depends onwhat you want to do with the second key.
A $0.99 cent WallyWorld duplicate will unlock the door & get you into the vehicle & start it.
If you have the securi-lock anti-theft system, the $0.99 cent key will still get you into the vehice, but you can't start it, UNLESS the programmed key is close by, in the cab!!!!
SO, if you don't care about the anti-theft system, just tape the programmed key out of the way, out of sight, close to the ignition switch & buy as many $0.99 spare keys as you like & drive up a storm!!!! lol
If you have the securi-lock antitheft system & you want to maintain your anti-theft protection, you can buy a repacement chipped key/s on Ebay & take it to a Dealer, or locksmth & pay for reprogramming.
As sorensenj said, you need at least two preprogrammed keys, to be able to program more keys yourself.
So buy your spare key from Ebay, the Dealer, or a Locksmith & pay them to program it. I'd buy an extra key or two & program them yourself, using the instructions in your owners manual, or just tape the programmed key you have, inside the cab & buy & use the cheap keys for spares, if you think you don't need the anti-theft protection.
Just some more options for consideration.
Old May 1, 2007 | 08:03 AM
kstiner's Avatar
kstiner
Thumbs down
Thanks Guys I was afraid of that. I will go to the dealership and take care of today thanks again.
Old May 1, 2007 | 12:20 PM
CougarXR02's Avatar
CougarXR02
buy two. It was like $50 to get one new key, and get it programmed, adding a second only cost $20 more.
You are able to trick the vehicle into thinking that key #1 is Key #3 in the slef-programming sequence, but it only holds the code for short periods.
Old May 3, 2007 | 06:37 AM
sorensenj's Avatar
sorensenj
Pawpaw makes a good point about taping the coded key near the ignition switch area and using a regular key to unlock doors and start vehicle. I've heard of people doing this and it works out for them.
Cougar makes a good point: buy two so you always have a couple of back-ups.
Jeez, these keys are getting expensive!
