Sponsored by: Real Truck
Auto Lock Hubs
Old Apr 30, 2007 | 11:43 AM
79CEEJAY's Avatar
79CEEJAY
Auto Lock Hubs
Did my "Front Bearing Service" this weekend. After replacing o-rings on both bearing assy and hub, thought the a/c would straighten out and not blow thru the defrost upon locking the hubs. However, that did not help. I think I have narrowed it down the the PVH solenoid. The hubs seem to hold about 12-15 hg of vacuum, so I assume they are not leaking. However, upon unlocking them in auto mode they still stay locked. If I go to "lock" mode on my hub and then back to "auto", they unlock. Also, the hubs are "impossible" to turn by hand....very, very stiff. Is it possible the hub diaphram is shot also? I disassembled them and regreased them and all the internals looked very clean, I can only assume that diaphram has possibly swelled and is causing them to be uncommonly stiff.
Anybody have any ideas?
Old Apr 30, 2007 | 01:09 PM
79CEEJAY's Avatar
79CEEJAY
Well, it appears that AFTER I wrote this post, I went ahead and searched other forums and it appears that I ended with all the diagnostic answers I need. Heck, I may just go with the manual hubs and plug the lines. I don't mind getting out to lock the hubs. At leat when they are locked they are locked and when they are free they are free.
Old Apr 30, 2007 | 01:40 PM
redford's Avatar
redford
FTE Leadership Emeritus
I stay with manual hubs. If you think you may need them, just lock them before you leave. If you need 4 wheel drive, engage the transfer case and go. When you are out of the area you need 4x4, just disengage the transfer case.
It doesn't hurt anything (except fuel mileage) to drive with the hubs locked and the transfer case in 2H.
Old May 3, 2007 | 10:13 PM
RACERX7775's Avatar
RACERX7775
Smile
can anyone get the number for the warn premiums or the mile marker stainless steel hubs for an 01 excursion. thanks.
Old May 3, 2007 | 10:26 PM
krewat's Avatar
krewat
Exactly.
I had the part number for the Warn premiums memorized, and lost it
Someone will be along soon...
Old May 3, 2007 | 10:37 PM
Trouble1263's Avatar
Trouble1263
[QUOTE=RACERX7775]can anyone get the number for the warn premiums or the mile marker stainless steel hubs for an 01 excursion. thanks.
Just ordered Mile marker hubs from Summit Racing.They were # 449ss. There was a write up on the install but the web page must have expired. Can anyone refresh this write up?? It was posted By BFR250SD
Old May 4, 2007 | 02:29 AM
blackhat620's Avatar
blackhat620
Warn premium hubs, # 38826 (this is for Dana 50 30 spline count axles).
Warn premium hubs, # 62672 (this is for Dana 60 35 spline count axles)
Mile Marker hubs, # 449SS (this is for Dana 50 30 spline count axles)
Mile Marker hubs, # 459SS (this is for Dana 60 35 spline count axles)
The F250 SD switched to Dana 60 front axles in late 2001.
Hope this helps
Old May 4, 2007 | 08:48 AM
Ed in Maine's Avatar
Ed in Maine
It says something about requiring a conversion kit on the SummitRacing web site to go from auto hubs to the 449SS ones? Is that needed? I like the price of the mile markers much better than Warn!
Old May 4, 2007 | 03:01 PM
Trouble1263
Ed, I talked to the fella at Summit and he said I did not need a conversion kit . I installed the hubs today, it was pretty simple. Capping the vacuum lines was the hard part, but not too bad. I still wish someone could refresh the write up on this, the pics really helped..
Old May 4, 2007 | 04:28 PM
krewat's Avatar
krewat
An Advanced Search with username BFR250SD yielded:
https://www.ford-trucks.com/forums/4...-complete.html
The Word document is long gone... I'll contact him to see if it's still available somewhere else.
Old May 5, 2007 | 11:07 AM
Trouble1263
Thanks krewat
Old May 15, 2007 | 11:58 PM
blackhat620
Alright i found the document that shows the hub swap with pictures. PM me with your email and i will send you the doc.
Old May 16, 2007 | 12:46 AM
RACERX7775's Avatar
RACERX7775
blackhat, could you please send it to me as well. i would appreciate it..
Old May 16, 2007 | 01:19 AM
blackhat620
No problem, PM me your email and i will send it
Baatzy
28
Jan 23, 2015 09:55 AM
cattlerancher
Nov 27, 2014 08:43 PM
BlackJeep
17
Jan 2, 2009 04:37 PM
hdman6
Sep 19, 2008 08:41 PM
