Turbo leak
Old Apr 30, 2007 | 11:09 AM
Reptar360's Avatar
Reptar360
Turbo leak
I made an adaptor to pressurize my intake and look for what seemed like a leak that I couldn't pinpoint. Truck runs OK but boost seems a bit lower than I remembered. Applied a constant 10 psi. I see 6 psi at the map connection. I can hear air moving continually. Sprayed soap on every connection. What I found is that the turbo leaks most of the way around between the aluminum "snail" and the aluminum back plate. What would be the best way to re-seal this? Are there any sealers that I should avoid?
Old Apr 30, 2007 | 01:22 PM
tjbeggs's Avatar
tjbeggs
there is an o-ring in there that is the seal. I would contact this guy
http://cgi.ebay.com/ebaymotors/FORD-...em120112802132
call his phone number right there in the auction. I have dealt with him and he is awesome. He will have everything you need
BTW could you describe what you built to pressurize your system? I need to do the same to test my intercooler pipes I built this weekend.
Old Apr 30, 2007 | 02:56 PM
Reptar360's Avatar
Reptar360
Thanks for the link.
I used a 4" ABS clean-out. 4" OD on one end and a threaded cap on the other end that I tapped for a 1/4" air fitting to connect to my compressor hose. I have an external regulator on my compressor that I was able to turn down to 10 psi. Actually I was afraid to apply any higher pressure. It fits the hose for my air filter. I am running a ccv mod so no pressure goes that way. I saw something like it on one of the sponsors sites to do exactly what you describe. Don't remember who it was.
Old Apr 30, 2007 | 03:15 PM
tjbeggs's Avatar
tjbeggs
cool thanks. I have seen pics of something like that too. I will be doing that soon. thanks for replying!
