New Floor Pans
Old Apr 30, 2007 | 09:19 AM
Broken40's Avatar
Broken40
New Floor Pans
I'm just curious, does anyone know where i can get a pair of floor pans that will replace the ones i have in my ford, mine are rusted thru and i need some new ones. I have a couple of buddies that are just telling me to cut out the floor pans an weld in regular sheet metal, but i wanna make it look stock again.....any ideas.
Old Apr 30, 2007 | 09:34 AM
BigGrizz76's Avatar
BigGrizz76
Our Sponsor has them:
http://blueovaltruckparts.com/catalo...ords=floor+pan
looks like that they are reasonable priced too.
Old Apr 30, 2007 | 10:56 AM
BigBad352's Avatar
BigBad352
Try blue oval, LMC, or NPD. I think they run around $39.95 in NPD.
Old Apr 30, 2007 | 11:07 AM
jostrowski's Avatar
jostrowski
I need to do the same thing. I Know that bronco graveyard and dennis carpenter also has them. The prices are all comparable of about $40. Does anyone know how much of an area the floor pans cover? (do they go all the way under the seat?)
Old Apr 30, 2007 | 11:11 AM
BigBad352's Avatar
BigBad352
Dont quote me but... I think they go up to the edge of the seat, and they are 29 inches wide.
Old Apr 30, 2007 | 11:18 AM
Franken-Truck's Avatar
Franken-Truck
The ones I bought went from the front cab seam to the top edge in the rear just under the front of the seat. Width wise from the top edge on the tranny hump to the door sill. You really get enough to do the whole floor. The rest of the cab floor is regular sheet metal. . .I think I have some pictures if you want.
Mind you, the sheet metal on these parts is a lighter gage metal, and you may need to reinforce the floor underneath some.
Old Apr 30, 2007 | 11:26 AM
jostrowski's Avatar
jostrowski
Pictures would be great.
Old Apr 30, 2007 | 11:32 AM
4starcstms's Avatar
4starcstms
Eh I'll upload a few, I just put pans in two different trucks.. got mine from a local aftermarket supplier (the same ones sold by NPD, Jeffs, LMC, and BOTP). If you put floor pans in, put Cab Mounts in too. Its only a little bit more work, and chances are if the floor is shot...the mount is too.
The floors go from the firewall to the top edge of the footwell.. I'll post up the pics in a minute.
Old Apr 30, 2007 | 11:39 AM
4starcstms's Avatar
4starcstms
https://www.ford-trucks.com/user_gal...149811&width=2
https://www.ford-trucks.com/user_gal...149812&width=0
I hope those links work, if not, goto my gallery in the More Monster TIgger pics and they are WAYYY down @ the bottom.
Old Apr 30, 2007 | 02:51 PM
jostrowski's Avatar
jostrowski
Is the footwell the part that the seat bolts to? Can you order one of those also?
Old Apr 30, 2007 | 07:38 PM
Franken-Truck
I don't think so. Where the seat bolts too is too simple to necessitate an aftermarket stamping. It's basicall all simple shapes and flat sheet metal you should be able to cut out yourself. If your talking about the front seat brace, I do beleive a few people carry that but it will be a bear to remove. . .
. . .I'd post my pics, but I see 4stars beat me too it
Old Apr 30, 2007 | 08:28 PM
JBradley500's Avatar
JBradley500
does anyone know what the reason for these rusting so commonly is?? mine are both to the point where you can see carpet from the outside.
Old Apr 30, 2007 | 10:06 PM
4starcstms's Avatar
4starcstms
No seam sealer where the cab mount meets the floor pan, also there is no sealer around the crossmember that runs under the seat. Nobody reproduces the parts under the seats. Rust just isnt that common in that area.
Old May 1, 2007 | 08:38 AM
BigBlue88's Avatar
BigBlue88
I have a set of floorpans just kind of sitting in place over the rust in my truck. How did you guys mount yours? Did you bother cutting out the rusted areas?
Old May 1, 2007 | 08:49 AM
Broken40's Avatar
Broken40
That was going to be my next question...i would assume would cut the old stuff out at the seams where the new ones meet and tach the new ones in......i would suppose.
