fuel filter
Old Apr 29, 2007 | 11:54 PM
royallenz06's Avatar
royallenz06
fuel filter
88 f150 302
is there supposed to be a filter in the canister/block where the fuel lines meet from the dual tanks? i was told that there is but i checked all the local parts stores and no luck. i unscrewed the canister of the bottom and there is no filter there. just a pickup tube looing thing? is this supposed to have a filter or is the on inline the only one? thanks.
Old Apr 30, 2007 | 12:12 AM
F150xlt's Avatar
F150xlt
Ford says the fuel tank selector valve on a 88 is a non serviceable unit.
No individual parts are sold for it.
You can buy a new one from Ford for around $65.00.
The only repaceable fuel filters is the one in front of the high pressure pump
which is mounted on the driveside inside frame rail and the fuel socks
which are snapped on to the bottom of each intank fuel pump.
Old Apr 30, 2007 | 01:36 AM
royallenz06
how come the cap will unscrew if it is nonserviceable? also on my buddies 1986 he has the same setup as far as i can tell but it has a filter in there? according to autozone there is filter for some of them but whats the diff. between ? the pn is ff616. thanks
Old Apr 30, 2007 | 05:24 AM
F150xlt's Avatar
F150xlt
That's just the way Ford decided to market that dual function reservoir.
Here's another example:
For 88 and 89's they only sell the fuel tank sender unit with the intank pump.
You can purchase a non OEM intank replacement fuel pump, but no one sells an exact replacement fuel sender.
Old Apr 30, 2007 | 02:54 PM
royallenz06
ok well thanks. that doesnt make sense to me why ford would have the same parts but only make some of them available but whatcha goina do? well i learn something every day. thanks
Old Apr 30, 2007 | 05:28 PM
quicklook2's Avatar
quicklook2
a good rule of thumb is not to trust autozone for advice on anything.
Old Apr 30, 2007 | 08:45 PM
Phillip Guidry's Avatar
Phillip Guidry
From my experiance..the 86 and 87 EFI's had the canister filter in the reservoir........the 86 did not have the inline high pressure filter.....but the 87 had both.......88 on up only had the inline high pressure filter.....
Old May 9, 2007 | 06:12 PM
buddywest's Avatar
buddywest
buddywest
I have an 88 F150 -- 302 EFI dual tank. I want to replace the fuel filter, but was told I would have to release the pressure in the fuel line. Does anyone know the easiest way to do this ??
Old May 9, 2007 | 07:14 PM
F150xlt's Avatar
F150xlt
If you look under the hood behind the air filter housing (firewall side mounted above the plastic wheel well housing) is a metal bracket that holds two relays. One relay is for the computer and the other relay is for the fuel pumps.
The ECC (computer) relay has the following colored wires at its socket.
White/Light Blue, Yellow, Black and Red.
The fuel pump relay has the following colored wires at its socket.
Red, Tan/Light Green, Brown and Yellow.
Pull/remove the Fuel Pump relay from its socket and start the engine. The engine will run for about 10-20 seconds and then stall because of no fuel.
Old May 9, 2007 | 08:01 PM
buddywest's Avatar
buddywest
Buddywest
Thanx F150XLT...I went outside and had no problem locating the relays. I'll start the job Tomorrow AM as soon as "The Old Lady" pulls her Nissan out of the garage.......Thanx again....
Old May 9, 2007 | 08:13 PM
FLYBOY07's Avatar
FLYBOY07
sadly that the best piece of advice i've ever read on here
