problems with new msd igition
Any help would be very much appreciated.
Ryan
What confuses me, is it is just off the start. After it get's rolling, hold on.
sounds like you have a problem with your accelerator pump circuit, not enough too much, or not working at all.
A mech advance only distributor is only good for high RPM racing applications. You can get them to run on the street but the vehicle will run like crap compared to how it would with a good distributor.
I DID have a slight hesitation with the duraspark, but now that I have the MSD, it much worse.
Also, if I hit the gas hard right away, there is no hesitation. There is only hesitation when I hit the gas gradually, like when I'm behind one of those import things.
I have no clue if that makes sense, but those are the symptoms.
The MSD 6AL ignition also does not contain the start timing retard circuit which is often needed with the 460 for easier starting. The MSD system is not nearly as good as the stock OEM DS-II system with the OEM type Motorcraft ignition module. MSD is more expensive to begin with and much harder and higher $$ to troubleshoot and repair.
The OEM DS-II has several advantages over the other aftermarket units for normal use. It has the timing retard function for easier starts especially with a hot engine and big cubes or high compression. Lower starter amperage means less wear and heat in the starter and cooler cables with less voltage drop. The DS-II is also optimized for performance below about 5K and gives a few more ponies on the low end than the aftermarket units that are generally optimized for high RPM operation. The OEM modules are easy to test at just about any parts store for free. You have to buy another aftermarket unit for shotgun testing on those systems. The DS system is much cheaper than the aftermarket units, even buying a brand new Motorcraft module!
As to high rpm race, well actually not so much, if your stall is 3500 rpm then whats the point of having a advance at all, and in fact most of the racers I know, me included don't run any advance my timing is locked out at 32 degrees, and I can and have done it to prove the point stomped the throttle off idle with 32degrees of advance right at that point, and no stumble at all, in fact it revs so fast you can't get your foot out of it before it hits the shift light if your free reving it. ooops so much for the theory of to much to fast causing a stumble off idle. Now why doesn't mine stumble? gee maybe cause the carb is dialed in properly.
Also the 6al box is not a high rpm box for racing only, it's actually a street box and is basically all done at 6000 rpm (goes to single spark around 4500 rpm)
another cute little fact that seems to be overlooked in this discussion, a stock or any vac advance dist is 85% mechanical, the vac only makes a few degrees of difference plus or minus which won't cause drivability problems unless something else is wrong, then it's just covering up the real problem. you put a advance curve on a mech only dist to run right up the middle of what the vac/mech will do and you won't see any difference as the total difference at any given moment will not exceed 2 degrees, and most timing marks on stock dampeners are actually off by more than that.
Last night I searched my memory to figure out how many mechanical advance dist I have run on the street, currently I have had 12 of my own, not one ever stumbled off idle unless I had a vac leak or a mis adjusted or bad carb. My dad runs a mallory on his pickup, mechanical only (I actually don't like the mallory but that has to do with the stupid photo cells that go out all the time) he has had it on that truck for 15 yrs, and he did in fact have a stumble off idle, had a local guy talk him into putting a vac/mech advance dist on it, and golly still had a stumble although not quite as bad. The guy then tells him well you also have a bad carb, so dad took the truck home and bought a new carb stumble went away totally so out of curiosity put the mallory back in and gosh no stumble gee maybe the carb was the problem, oh no couldn't have been he just got lucky with the new one I guess.
I ran one in a 454 GMC 1 ton I used for towing my stock trailer had it 6 yrs pulled a 28ft gooseneck trailer with up to 18,000lbs of cows at a time, got 11mpg loaded and 13 empty with 4.56 gears and a 4spd. and once again no off idle stumble EVER, guess I was just lucky.
And I will still say that even if you do get a mech advance only distributor to "run" on the street it will run like crap compared to a proper setup with a vacuum unit. They just don't run right without a vacuum unit for part throttle period. Timing has to have the load input into the equation. There is a world of difference in getting something to "work" vs getting something to work right. Hell even MSD makes a distinction between street and race distributors, guess what, the street distributors have vacuum advance units!
The MSD 6AL "advertised" specifications:
OPERATING SPECIFICATIONS
Operating Voltage: +10-18 VDC Negative Ground
Current Requirements: 5 Amps-5,000 RPM
10 Amps-10,000 RPM
RPM Range: 15,000 RPM with 14.4 Volts
Spark Duration: 20° Crankshaft Rotation
Energy Output Max: 105-115 mJ Per Spark
Weight and Size: 3 lbs, 8"Lx4"Wx2.25"H
Voltage Output Max: Primary: 460-480 Volts
Secondary: 45,000 Volts (Blaster Coil)
http://www.msdignition.com/ignition_6_6420.htm
As to not having a clue, well thats funny ASE master auto tech, second highest graduating score from WTI, only student offered a job as an instructor before graduating, CCT journeyman in diagnostics, electronic, and drivability as well as trans and a couple others. i may be a dumb ole truck driver but wasn't always one. I also know that every drivability problem that you ascribe to a mechanical advance dist usually isn't, I have seen to many put on a vac dist and find out the problem still exist just like it did before. wonder of wonders.
the vacuum advance is for economy not drivability issues as you ascribe to them, yes you CAN get a vac dist to get better fuel economy in variable driving formats than you can a mechanical but they DO NOT CURE THE DRIVEABILITY ISSUES, well unless you have the mechanical locked out. Do you know what the limp home mode timing is? it's a rpm only based timing curve, and guess what most people don't even realize it has gone into that mode as far as the way the car drives, Ford is real good at it. if the computor is in open loop it does not use vac as a source to figure the timing, it uses rpms just like a mechanical advance dist uses and guess what no off idle stumble, also as to the off idle issues you keep subscribing to mech advance dist, they DONT advance the timing until around 1400 rpm thus they aren't affecting off idle at all. and rarely does a vac advance even begin to advance until around there also with the exception of GM and some chrysler vehicle. also most of the early electronic timing controls did NOT use vacuum in figuring timing they used a knock sensor the timing computer would advance until detonation was detected (so slight as to not be noticable by the human ear, or cause any engine damage) then slightly retard and begin advancing again, several times a second. always going for max timing when it could unless the tps was in idle position.
edit for a clarification, you don't see me telling people to go out and buy a mechanical advance dist, but I do tell them if thats what they got it can work just fine thank you very much. instead of telling people to go out and spend another hundred or more on parts that aren't going to cure the problem.
