Hello and info
Old Apr 29, 2007 | 12:37 PM
jack125's Avatar
jack125
Hello and info
Hi,
I am happy to a memeber. I hope to learn a thing or two.
btw, If anyone ever had this problem before you start spending money.
Try this:
I have a 1999 Explorer 4.0L SOHC. My check engine light came on a couple months ago. Now that the weather is better I decded to check it out.
My plugs have never been changed so I did them, What a pain in the neck.
btw, 187k on the truck. I had the codes of PO442, PO171, and PO174.
After the plugs, I had my fjriend with a computer gixmo, erase the codes.
Started her up, and bingo, no more codes. Only the 1st day but things look good. So, it was worth changing the plugs. not to mention , they sure needed it.
I hope this helps others with the same problem.
take care,
JR
Old Apr 29, 2007 | 12:57 PM
Ultramagdan's Avatar
Ultramagdan
Hello JR and Welcome to FTE!
Nice intro and I'm sure you will learn a lot here. You will want to stop by the Explorer forum if you haven't already. (Click on Forums at the upper left and scroll down the list.) Be sure and checkout your regional chapter to find what's happening in your area. Here's the link: https://www.ford-trucks.com/forums/forum158/
See you on the boards.
Old Apr 29, 2007 | 01:24 PM
jack125's Avatar
jack125
Thanks for the welcome.
bambam634
New Member Introductions
Jan 21, 2008 07:26 AM
castro106
Jul 31, 2007 10:47 PM
rrzabo
Jul 16, 2007 04:47 PM
Truck Issues
Mar 19, 2007 04:02 PM
sooneray
Jan 13, 2007 01:41 PM
