Small or Big Block
Old May 2, 2007 | 08:42 PM
  #31
benshere's Avatar
benshere
Fmx
Rats!
Guess I'll have to get one the old fashioned way-----steal it!
Old May 2, 2007 | 08:52 PM
  #32
havi's Avatar
havi
I'll have the Roast Duck
Consider this, the odds of you finding one tomorrow in a nearby jy is the same as finding one 10 years from now, lol. Just don't give up.
Old May 2, 2007 | 09:04 PM
  #33
danlee's Avatar
danlee
Look at ads in the paper for a '73 Ranchero. Then check it out to see if it has the FMX. Many did not.
Boneyards are another source.
Old May 2, 2007 | 09:14 PM
  #34
benshere's Avatar
benshere
Fmx
You guys talking about an FMX block or the FMX transmission-----or maybe and FMX block with an FMX transmision? My head is beginning to hurt!
Once had a 78 LTD (full size) with a 400 motor and had a xmission that was alum bell and iron case. I figured it was an FMX transmission. C6's are one piece alum case.
Old May 2, 2007 | 09:22 PM
  #35
danlee's Avatar
danlee
The so called 400 FMX block has a small block bell housing pattern and will mate to any small block tranny, like an AOD. I assume it gets it's name because it came with an FMX tranny attached.
Your 78 LTD might have had an FMX tranny, but it had a 'Big Block' bell housing.
Old May 2, 2007 | 09:26 PM
  #36
73XAFalcon's Avatar
73XAFalcon
We're talking about a very rare 400 block. Look closely at the pics of my motor and you will see that it has a small, 351C/W bellhousing bolted to it. In 1973, and maybe part of 1974, Ford made an unknown amount of 400 blocks that had an undrilled big bellhousing pattern with a drill small bell pattern. These motors were bolted to Windsor/Cleveland FMX trannys. Of the 8-10 I know of, half came out of Rancheros while the other half were found already pulled. A few years ago, several of us tried to figure out some method to Fords madness and the best we can tell is that Rancheros, Torino/Montego wagons, and possibly Torino/Montego sedans built in 1973 and equipped with a FMX tranny MAY have the small bell. However, most 400 equipped mid-size cars back then had C6s so it is a real crap shoot when looking for these. BTW, "400FMX" is just a term used by us 335 Series guys as it is the best way to identify the motor.
Old May 2, 2007 | 09:47 PM
  #37
benshere's Avatar
benshere
FMX and other mythical creatures
Tx, kinda already knew what they were, though rough on the details. I though I had a lead on one several years ago. A Cleveland man (car, not city) had one on his airboat. Crying, begging, kicking, screaming didnt work-----. He also had a 64 fairlane sports coupe out in front of his place, sitting in the grass! I'm embarassed to think what I might have done for either or both of them
Several places make an SFI adapter bell for several trannys and motors. One is fairly close to me in Titusville, Fl. 460 to small block works for 400. Dont know how strong though, you cut off the original bell and bolt new one on with pump bolts. Anyway more beating head against wall, which I seem to be good at.
Old May 2, 2007 | 09:57 PM
  #38
73XAFalcon's Avatar
73XAFalcon
Why not run a manual tranny? It is much easier to get a bellhousing and the bells are a lot cheaper. I've seen AOD-to-460 bells that were in the $600 range!!! The Tremec TKO500/TKO600 aren't that much more than a well built, high HP auto OD tranny especially if you have to buy a $600 bell for the auto. Besides, shifting for yourself is a helluva lot more fun than waiting for a slushbox
Old May 2, 2007 | 10:03 PM
  #39
benshere's Avatar
benshere
Tremec
I have seriously considered that! Again, probably the wiser thing to do. Although when I had my 67 vette (427, side pipes, both tops) with the M21, I swore I would give up manuals down here in traffic.
Same questions I asked DanLee---
Do you park yours outside at night?
Do you have any dogs?
Are you a good shot?
Old May 2, 2007 | 10:07 PM
  #40
73XAFalcon's Avatar
73XAFalcon
No.
Yes, and they don't like people.
Hell yes, and I shoot expert every time on both M9 and M16.
Old May 2, 2007 | 10:14 PM
  #41
havi's Avatar
havi
http://www.campbellenterprises.com/p...ry=jwp92454aod
is this something worth pursueing?
Old May 2, 2007 | 10:55 PM
  #42
benshere's Avatar
benshere
Ultrabell
Thats one of the bells I was talking about. In fact the mfg (J.W. enterprises) is the one located in Titusville, Fl. or used to be anyway. Just north of Cocoa Beach, Fl. I hope someone has some info on their strength. They attach to case with the tranny pump bolts.
Old May 3, 2007 | 06:09 AM
  #43
danlee's Avatar
danlee
Originally Posted by 73XAFalcon
No.
My brudda-in-law is named Vito.
Old May 3, 2007 | 08:33 AM
  #44
benshere's Avatar
benshere
Oops!
Too far for me to drive just to get eaten by dogs, shot and my kneecaps broken--. Think I'll pick on someone closer to me----so I can crawl home
Old May 12, 2007 | 01:33 AM
  #45
cruz76's Avatar
cruz76
Ha, I read an article on a windsor build up and were using stock 351c 2v open chamber heads because they have way more flow than stock windsors and other after markets. It was simple too, just a couple of holes that needed to be drilled to the heads while a couple had to be blocked and they were ready to bolt on.
