Requesting a picture
Old Apr 29, 2007 | 01:00 AM
DominionX18's Avatar
DominionX18
Is anyone willing to give me a picture of their factory 460 ford with factory smog equipment on it? I need to know how some parts are run and I have some things going off into nowhere. Any and all pictures would be great, thank you!
~Brian
Old Apr 29, 2007 | 05:26 PM
Mil1ion's Avatar
Mil1ion
I have illustrations galore.
Is this a california truck or 49 state.
You didn't even said what year your truck is
Please submit important info when requesting things like this.
Like the 302 guys.
There are 37 different hose routings for 77/78 302's due to trans type,rear axle,state of operation,altitude,model,4x2 or 4x4,etc etc.
Old Apr 29, 2007 | 06:16 PM
DominionX18
Like the 302 guys.
Sorry, Im still used to how generic the chevies are. Its a 1979 F250 with a 460 in it. Although, the 460 is out of a 68 lincoln, I donno how much that changes things.
~Brian
Old Apr 29, 2007 | 06:24 PM
Mil1ion's Avatar
Mil1ion
Is this Calif ? Well because the engine is pre-emissions is won't matter unless you have to honour 79 standards which is IMO a waste of a muscle engine.
There are EGR differences
Vacuum amplifier equipped.
I'll link a 78 460 diagram if you like
Oh ya, no need for the quote, I know who and what you are replying to
Old Apr 30, 2007 | 02:50 AM
DominionX18
yeah its a cali truck and cali smog. But it only has to pass for 68's standards as the engine was a legal swap that was grandfathered. There is missing stuff and I have no idea where what goes and how. Like there is two vacume lines that appear to come out of the sending unit for the temperater guage, I'll take a pic and post it up and you can tell me what all is wrong with it. How's that sound?
~Brian
Old Apr 30, 2007 | 02:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If you are in the Los Angeles area, I have all the parts catalogs which you are more than welcome to come look at. I can also eyeball your engine and tell you what's missing.
CA vehicles in 1968 had a smog pump on some, PC valve and evaporative emission. No EGR valves till 1973.
Old Apr 30, 2007 | 03:02 AM
DominionX18
Awesome! I live near the LA area, once I get this pig running smoothly I will probably take you up on this offer. What kind of beer do you like so I can bring a present with me. haha.
~Brian
Old Apr 30, 2007 | 03:04 AM
NumberDummy
~Brian
No beer needed, and no charge either. I added CA smog requirements to above post.
Old Apr 30, 2007 | 02:57 PM
Mil1ion's Avatar
Mil1ion
I have all the vacuum diagrams and some illustrations from 1966 cars to 1986 Cars & 1973-1986 Trucks.
Would you like the vacuum diagram from a 1968 T-Bird ?
here is a 1973 460 4v diagram
Here is the parts list.
Old Apr 30, 2007 | 05:59 PM
DominionX18
Would you happen to know the firing order for the 68 Lincoln 460? My miss hasn't gone away and I think its a firing order issue. THANKS!
~Brian
Old Apr 30, 2007 | 07:51 PM
Mil1ion's Avatar
Mil1ion
Look here
http://boxwrench.net/specs/ford_429-514.htm
same as others.
15426378
Make sure 7 & 8 wires are seperated on the valve cover holder so they don't possibly misfire
Old May 1, 2007 | 02:41 PM
DominionX18
I used that web site and set up my truck to follow that order and now it wont start. I think I am a frustrated ford owner now....
~Brian
Old May 1, 2007 | 06:13 PM
Mil1ion's Avatar
Mil1ion
Do you have the #1 position of the piston at TDC power stroke correlated with the #1 position of the Distributor cap ...with plug wires in correlation with direction of rotor travel ?
Each cylinder has 2 TDC's
Top of Power stroke and again at end of exhaust stroke
Old May 1, 2007 | 06:58 PM
DominionX18
I kept playing with it and figured out what was wrong. For some reason when I hook up the distributor up starting with the posted Number 1 sign it doesn't work. I shifted the wires over two poles and now its working. The miss has smoothed out but isn't gone yet. Im going to rebuild the carburator is next. Either its running good or Im not used to hearing the firing order of the 460 but it has more power now. It detonates a bit so I am going to reset the time as soon as my hand stops throbbing. I got too close to the fan and it bit me.
Old May 1, 2007 | 07:00 PM
Mil1ion's Avatar
Mil1ion
Yes Number 1 can be anywhere on the cap.
Everything else has to be in sequence and set up right though.
Band aid or Shot of Whiskey ?
