When you press the pedal brale fluid is pushed through the lines to the caliper pistons and wheel cylinder pistons.
When the brake pedal is depressed ..the pedal drops to the floor and there isn't any sign of leaking brake fluid anywhere, then the only thing it can be is.... flow back of fluid back to the master cylinder because the seals on the piston in the M/C have been comprimised and the fluid has to go somewhere..thus making the pedal drop to the floor.
