Sorry I Am New To This. I Thought I Was Posting A New Message.
No biggy. Next time you realize you goofed, just view your post and hit the edit button below it. At that point you can delete the text and type "post deleted" or something similar but you cannot delete the reply. You have 60 minutes to edit a post.
Read at your own will….I am quoting the dealer from the invoice!
<O</O
“INSPECT FOUND ALT NOT CHARGING TEST BATTERIES, PASS. INSPECT FOR POWER AT ALT FOUND NO POWER ON CKT 35 <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com[img] /><st1:City><ST1<IMG class=inlineimg title=[/img]ORANGE</ST1</st1:City> WITH BLUE WIRE, CHECK FUSE NUMB ER 6 IN BATT JUNCTION BOX FEEDING CKT OK. JUMP 12V TO CKT 35 AT ALT, ALT CHARGES NEED ADDITIONAL TIME TO FIND OPEN BETWEEN C 130 AND BATT JUNCTION BOX CLOSE TO C 130 UNDER AIRTAKE HOSE, REPAIR WIRE. REASSEMBLE OP CHECK ALT OK”
<O</O
There it is….If I read correctly it was a broken (damaged) wire.
<O</O
$90.00 hr
$00.00 parts
$270.00 labor
$299.20 w/ tax
<O</O thanks to everyone who tried….<O</O
