Sponsored by: Real Truck
Tranny shifts hard with code
Old Apr 28, 2007 | 09:45 AM
Sundance Kid's Avatar
Sundance Kid
Angry Tranny shifts hard with code
Hey, I have a 99 F-350 SD Crew Cab Dually with a V-10 and Auto tranny. The other day out of no where it started shifting hard ( like it wanted to rip the rearend out from under it). Check fluid level and it was good. Color was fine and it doesn't smell burnt. Then I got a service engine light. Put my code reader on it and got P0102 (Mass or Volume Circuit Low Input). Cleared the code and drove the truck and it came back on. Has anyone had this before or know what it could be. I'm guessing that the code has something to do with the tranny. Thanks for the help now and in the past.
Old Apr 28, 2007 | 10:42 AM
FortyFords's Avatar
FortyFords
Clean the mass air flow sensor !
the p0102 is the code for that and yes it will cause the tranny to shift wierd.
Rich
Old Apr 28, 2007 | 11:30 AM
Sundance Kid
Thanks for the input. A couple of weeks ago I had a surging problem with the motor and found the mass air flow sensor bad and a bad rubber elbow for the PCV. Replaced both and fixed the problem. Could this be related? And how does the MAF sensor affect how the tranny shifts?
Old Apr 28, 2007 | 02:01 PM
FortyFords's Avatar
FortyFords
The pcm use its input along with other sensors to determine when to shift.
It is all tied together within the pcm codes.
Rich
Old Apr 28, 2007 | 02:10 PM
Sundance Kid
Thanks FortyFords I'll look at it when I get home from work tonight.
Old Apr 29, 2007 | 10:49 AM
Sundance Kid
Well fortyfords I looked at the MAF that I had replaced a month ago and found the connector had come off. That fixed problem. Thanks for all the help!
Old Apr 29, 2007 | 05:54 PM
FortyFords's Avatar
FortyFords
Glad to hear your good!
Rich
