help with removal
Old Apr 27, 2007 | 10:00 PM
kodyowenby10's Avatar
kodyowenby10
help with removal
What can I use to remove the oil sending unit on my 1988 F150 with a 5.0 is there and tips for this or just get it out any way I can? The motor is still in the truck with everything hooked up.
Old Apr 27, 2007 | 10:58 PM
taisa899's Avatar
taisa899
are you talking about the oil pump that is located inside the oil pan?
Jim
Old Apr 27, 2007 | 11:05 PM
kodyowenby10
no the sensor that screws into the left front toward the bottom of the block and runs to the dash
Old Apr 28, 2007 | 01:25 AM
ryan f150 4x4's Avatar
ryan f150 4x4
there should be flat spots for a wrinch or alts you need a scokit to remove it most parts places have them. but mine is just 5/8 wrinch
Old Apr 28, 2007 | 01:26 AM
92F150Flare's Avatar
92F150Flare
Hi and welcome to the forum
Sending units usually are like a bolt that you screw in to the block. You should be able to put a socket on it and back it out. I've used deepwell sockets in the past. If there is no room you may have to just use a wrench. It's been in there a while and it's going to be torqued down good.....just break it loose and it'll back out. Try spraying it with some liquid wrench and letting it sit some before you try.
If the bolt head part is shot you might have to use vise grips. It doesn't matter because you're going to throw it away and put the new one in anyhow.
Good Luck
Old Apr 28, 2007 | 04:12 PM
mhg's Avatar
mhg
I dont recall the size socket to use but it must be 6 point
about 1 1/16"
they make a special oil sender socket if you wish to spend
about 8.00 for a cheap one
