looking for parts help?
Old Apr 27, 2007 | 07:01 PM
hdbugs's Avatar
hdbugs
Pulled the side tank of to replace brake line and the C shaped retainers (on the frame used to hold the tank to the frame) with the bolt built in are rusted to the point of unusable..any ideas where to find them? I have looked at the vendors on this web site and no luck.
truck is a 1978 F 250 Camper Special 4X4
Old Apr 27, 2007 | 07:13 PM
Mrcorey5's Avatar
Mrcorey5
Is the part you are looking for just a steel brake line bracket that secures the line and keeps it from rubbing the frame?
Old Apr 27, 2007 | 07:16 PM
hdbugs's Avatar
hdbugs
I edited my post to include that they are used to hold the tank holder to the frame.
Old Apr 27, 2007 | 07:29 PM
Mrcorey5's Avatar
Mrcorey5
At first I thought you were looking for brake line brackets.
Old Apr 27, 2007 | 07:34 PM
Mrcorey5's Avatar
Mrcorey5
Are you talking about the clips that slide over the edge of the frame and lines up with a hole. Then the bolt goes thru the frame hole and threads into the top part of the clip?
Old Apr 27, 2007 | 11:29 PM
4starcstms's Avatar
4starcstms
Sounds like it... You can get them from places like Gardner Wescott, as well as better autoparts stores... not Autozone or Advance, but Maybe Napa? I have a local chain called Kentucky Ohio Indiana autoparts..they have a HUGE selection of these kinds of things..very handy!
Old Apr 27, 2007 | 11:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
Those parts are available not only at auto parts stores but in larger hardware stores also. They can also be found by the thousands in auto scrap yards.
Old Apr 28, 2007 | 09:27 AM
hdbugs's Avatar
hdbugs
Mrcorey5 that is what I am looking for, I have been to wrecking yards and so far have found junk not worth tearing apart for hours and the auto parts stores look at me like huh? I do appreciate the help and will keep looking.
Kevin
Old Apr 28, 2007 | 09:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Are you asking for gas tank straps? I doubt autoparts stores would have them. Each type of tank uses a specific type. Prolly Ford only.
Which tank, front or rear? Steel or plastic? Engine size is?
