Vacuum Gauge Hookup
Old Apr 27, 2007 | 04:49 PM
dustinova's Avatar
dustinova
Vacuum Gauge Hookup
I am going to hookup the vacuum gauge I just purchased this weekend to check on the condition of my 351M in my 78 F-250 (see my sig). The manual says to hook it up to "manifold vacuum" but I have no clue where that would be. Would I hook it up to a vacuum port on the carb (The motor has an Edelbrock 600cfm electric choke carb). As far as I know, it is the stock intake manifold. Thanks.
Old Apr 27, 2007 | 05:50 PM
53fatfndr's Avatar
53fatfndr
There should be a few vacuum ports on your intake manifold, some of them might be "capped" off with rubber plugs.
Old Apr 27, 2007 | 09:34 PM
Jermafenser's Avatar
Jermafenser
The manifold vacuum is located way back of the engine. Remove the air cleaner. Look further up north of the carburetor. The manifold vacuum resemble a flute.
Old Apr 28, 2007 | 06:51 PM
packlet's Avatar
packlet
yup. passenger side in the back of your intake manifold there will be a 'tree' with a bunch of vacuum ports on it. some are probably unused and capped off. just hook your gauge up to one of those.
