2000 Rims
Old Apr 27, 2007 | 04:39 PM
Suber's Avatar
Suber
2000 Rims
I found a set of rims for pretty cheap. Stock Ford 8 lug, Aluminum rims (100.00) for all 4. My question is will they fit on a 97' 4x4 Crew Cab? I have hears that some later years have an offset and they wont work on the late 90's trucks. I would sure like to buy these rims if they will fit. Thanks, Suber.
Old Apr 27, 2007 | 05:08 PM
DAN-D-DIESEL97's Avatar
DAN-D-DIESEL97
bolt pattern spacing is different.
Old Apr 27, 2007 | 06:04 PM
Suber's Avatar
Suber
Thanks for the info. Which rims would fit my truck other than 97 of course? I am guessing maybe up to 99 would work on my truck.
Old Apr 27, 2007 | 06:24 PM
Cuda_jim's Avatar
Cuda_jim
Everthing up to a 97 fits your truck, they chnged in 98. Sucks HUH! I wanted to do the same thing, no go.
Old Apr 27, 2007 | 06:32 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You don't even have to use Ford wheels. Up until the Fords bolt pattern changed with the introduction of the Superduty, all of the big three used the same bolt circle on the 8 lug wheels.
Of course, if you put a set of D*dge wheels on your truck it would probably have an allergic reaction to them.
