Offroad & 4x4
how about a 1-link?
Old Apr 27, 2007 | 04:32 PM
jgreen's Avatar
jgreen
how about a 1-link?
been cruisin the web looking for rear suspension ideas and have stumbled across the 1-link, or wishbone suspension.
i would not use a trailer ball, something seems wrong about that, but a tractor rod end or something seems like just the ticket..
i wouldn't have to worry about leaf springs, i have some coils i could build perches for.
and i wouldnt need ladder bars either, i would have built in axle wrap prevention.
watcha think guys?
Justin
Old Apr 27, 2007 | 04:49 PM
jgreen's Avatar
jgreen
it is a triange with two bars /\ and the axle __
the point of the triangle mounts under the tcase via a large heim or johny joint or something and can act as protection for you rear driveling while offering unlimited articulation. some people have been known to use trailer ***** and hitches for the mount. thats kinda ghetto, but evidently functional. not for me.
the bars are welded or bolted solidly to the axle.
for the record......i am prepared to get flames.......
Justin
Old Apr 27, 2007 | 08:24 PM
Skinsfan6's Avatar
Skinsfan6
Interesting...could you find some pictures of it done on a truck and post them?
Old Apr 27, 2007 | 08:40 PM
monsterbaby's Avatar
monsterbaby
you still need some kind of trac bar or panhard bar because the wishbone style does nothing to locate the axle side to side.
Old Apr 28, 2007 | 06:54 AM
Thomasm67's Avatar
Thomasm67
That's what i was thinking Rob.
Old Apr 28, 2007 | 09:19 AM
B-one's Avatar
B-one
ive done a little research on this, and the flex is outrageous. there is a scout on pirate that did this one link, and he used the ball and caps from a *gallion motorgrader*. i dont have the part numbers in front of me, but i emailed the guy and they are 160$ for just the ball and caps. i plan on doing this to my eb next winter.
Old Apr 28, 2007 | 10:24 AM
jgreen's Avatar
jgreen
yeah you have to have a panhard bar to locate the axle, but it is simple and fairly cheap in the end.
Justin
ill find some pics.
Old Apr 28, 2007 | 02:02 PM
jgreen's Avatar
jgreen
heres a couple of pics
http://s172.photobucket.com/albums/w...railerBall.jpg
http://s172.photobucket.com/albums/w...neLinkRear.jpg
Justin
Old Apr 28, 2007 | 03:02 PM
B-one's Avatar
B-one
personally, i would shy away from the trailer ball type. it just looks too cheesy to work good.
Old Apr 28, 2007 | 04:03 PM
jgreen's Avatar
jgreen
yeah, that was just so everyone would understand what i meant in my first post.
if i do this for my rear suspension, i will use a big tractor rod end or a monster johnny joint or something.
i am acutally thinking about keeping my leaf springs and using this just as a trac bar for now....then in the future going to coilovers when i can afford to spend $400 on a shock.
i could just do a shackle flip, lower the front of the rear spring and build 10" spring perches for my axle. about 16" of lift or so and have this one link control my axle wrap.
Justin
Old Apr 29, 2007 | 04:48 PM
jgreen's Avatar
jgreen
i looked at my truck today and it looks like i would need bars about 6-7 feet long, do you think this would be okay, or would that be too long?
Justin
Old Apr 29, 2007 | 06:16 PM
RawPower's Avatar
RawPower
Well, if you keep your leaf springs, then a wishbone link is absolutely useless. As a metter of fact, it is counter-intuitive. You don't need anything on a leaf spring set up to trac the axle where it needs to be, the leaves do that well enough. The wishbone linkage will actually impair you articulation on a leaf spring set up, as the axle will want to travel on a different radial path than the wishbone, which will trac in correspondence to the pivoting frame mount.
So until you swap over to coils, coilovers, or airbags, don't waste your time...
Old Apr 29, 2007 | 07:14 PM
Hooker Bob's Avatar
Hooker Bob
This guy has done quite a few of these.
www.horizonoffroad.com
Pat
ftowelding
Jan 26, 2009 07:35 PM
JustinSWeber
Jan 7, 2008 12:37 AM
hoxiii
Apr 26, 2007 11:27 PM
Ratfink
28
Feb 15, 2006 12:37 AM
1Bad82
Jul 20, 2001 07:30 AM
