starter shatered, need help
Old Apr 27, 2007 | 09:25 AM
mex2popper's Avatar
mex2popper
does anyone know how the starter housing would chunk apart? it happened to me and it grinded up my fly wheel, 2 pieces came off of it 2 inches in diameter.
-steve
Old Apr 27, 2007 | 10:25 AM
Redneck1465's Avatar
Redneck1465
I have only seen that once before and that was because the engine had coolant in the cylinders and it had created so much pressure that when the starter tried to turn the engine over it couldnt do it and it shattered the housing for the starter.
Old Apr 27, 2007 | 10:31 AM
Duncan10's Avatar
Duncan10
If I understand then one possibility was loose bolts on the starter maybe moved the wrong way if it was loose.
Old Apr 27, 2007 | 06:21 PM
mex2popper's Avatar
mex2popper
there is no coolant in the cyilinders, it was making wierd sounds when i got it.
Old Apr 27, 2007 | 07:19 PM
Redneck1465
What was making the weird sounds??? The Starter??
Old Apr 27, 2007 | 07:34 PM
mex2popper's Avatar
mex2popper
yes, when i went to start it, there was a buzzing sound, then i would have to roll it forward, get back in, then it would start.
Old Apr 27, 2007 | 08:37 PM
Redneck1465
Hmm sounds almost like the starter wasnt grabbing onto the flywheel. Is your truck a manual??
Old Apr 27, 2007 | 08:39 PM
mex2popper's Avatar
mex2popper
yes, it is a 4-speed
Old Apr 27, 2007 | 08:51 PM
Redneck1465
When you roll it forward, you are moving the flywheel and that leads me to believe that maybe you have some teeth missing on it and somehow someway when your starter tried to engage is caught wrong over the broken teeth and that shattered it. There should be a small place where you can pull down a gaurd under the trans and you can have someone spin the engine over for you and watch the flywheel to see if you have broken teeth on the flywheel. If you do you should prolly replace that flywheel and put a new starter in and you should be good to go.
Old Apr 27, 2007 | 08:57 PM
mex2popper's Avatar
mex2popper
that sounds about right
Old May 21, 2007 | 03:44 PM
mex2popper's Avatar
mex2popper
i put a new starter on it and now it starts up perfect!
