Sponsored by: Auxito
Suspension problem
Old Apr 26, 2007 | 07:45 PM
Braker 19's Avatar
Braker 19
Suspension problem
97 F-150 2WD 130xxx miles. Truck leans pretty hard to the drivers side. What all could cause this?
Old Apr 26, 2007 | 08:24 PM
AnOldDog's Avatar
AnOldDog
Does it lean while it is parked, or does it pull while you are driving?
Old Apr 26, 2007 | 08:44 PM
Braker 19's Avatar
Braker 19
It leans all the time. Doesn't pull at all.
Old May 1, 2007 | 12:30 AM
explodingvarmit's Avatar
explodingvarmit
my 98 4x4 leans 2 in lower on the driver side as well. looking for any suggestions.
Old May 1, 2007 | 10:11 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I would suspect that the coil spring has failed. My friends '67 Chebbie used to sag really bad on the passenger side. I helped him put some of thoes cheap coil spring spacers between the coils last year. They are holding up, and leveled out the ride.
Old May 1, 2007 | 10:32 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
theres no coil's on these trucks
Old May 1, 2007 | 10:34 AM
BURNSTOUGHFORD
Myne leans as well to the drivers side, not much... i think my frame might be bent
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
