02 Explorer - brakes squeak
Thanks in advance..
- Tom
The first step in silencing noisy brakes is to do a complete inspection of the braking system to identify the source of the problem. Check for excessively thin brake pads scored or warped rotors, brake fluid leaks and oil or grease on pads. In your case, since you just had a new system installed, this is most likely not the cause.
Make sure pads and shoes have not worn down to the metal backing plate. Look for rust or corrosion that can prevent proper functioning such as a piston sticking in its cylinder(s). Check pads and shoes for equal side-to-side wear to determine if a piston might be sticking leading to unequal wear.
Often the braking system checks out okay, but squealing persists. While probably not affecting braking safety and effectiveness, the noise can be irritating. If the squeal comes just as you about to come to a complete stop, often the reason is a brake pad that is vibrating against the rotor's friction faces or caliper.
One solution here is to install vibration dampeners. These are made of a self-stick fiber material, which adheres to the back of the brake pad backing plate to dampen brake pad vibration.
Another solution is to coat the back of the brake pads with an anti-squeal compound, a thick heat-resistant polymer adhesive applied to the back of the pad to provide a cushion between the pad and piston as well as help the pad retract with the piston.
This material comes as an aerosol spray or as a liquid. Coat only the area that contacts the piston, making sure that it does not get onto the front, contact area of the pad or rotor. Here is a link to this type of product. http://www.international-auto.com/index.cfm/fa/p/pid/2764/sc/8140
