1970 Body Swap
Old Apr 26, 2007 | 01:18 PM
rickfixit's Avatar
rickfixit
1970 Body Swap
I have 2001 F150 supercrew chassis and plans to put a 1970 F100 body on it. The wheel base of the new truck is 8 inches longer. Need ideas or articles of someone who has done this.
Old Apr 26, 2007 | 01:23 PM
arctic y block's Avatar
arctic y block
I've never done that one. But have put older bodies on newer chassis. I can tell ya that if it isn't a real close match to start with ya better have a well equipped shop. And the knowledge to fabricate. Good Luck
Old Apr 26, 2007 | 03:05 PM
rickfixit's Avatar
rickfixit
Thanks, I'll try to update the project as I go.
Old Apr 26, 2007 | 06:18 PM
arctic y block
One thing I've done in your case with a longer chassis. Is to lengthen the box by welding two together. It gives you the ride of a longer wheel base and more cargo area. And on a Bumpside with a two tone paint it is not that notisable. Just a thought. And it is kinda cool. Ya can put a two foot deep tool box in and still have an 8 foot cargo bed.
Please keep us posted and Welcome to FTE.
Old Apr 26, 2007 | 08:44 PM
clloyd53's Avatar
clloyd53
With decent welding and cutting skills you can cut off the rear of the cab and extend it the 8". With the fuel tank gone you could have a custom extended cab. Depends on how far you want to go with it. Good luck and enjoy your new project.
Old Apr 26, 2007 | 11:16 PM
Redcat Diesel's Avatar
Redcat Diesel
If you don't want to go with custom sheet metal you might want to consider shortening the frame to match the wheelbase.
Old Apr 26, 2007 | 11:28 PM
42ninef100's Avatar
42ninef100
I put a 69 Ranger swb on a 79 4x4 swb frame no problem 3'' gap between bed and cab looked cool gave plenty of flex with no rub.8'' is going to give you fits on the body. I would shorten frame . An experinced welder can do this we have done road tractors to dumps no worries.
Old May 1, 2007 | 04:32 PM
rickfixit's Avatar
rickfixit
F100
My plans are to keep the classic look of a F100 but the handling of a newer truck. Cutting the frame is the only way to go for me.
Old May 1, 2007 | 05:05 PM
Marz-68's Avatar
Marz-68
just cut the frame and shortend it then plate the sections were you welded it back to gether with 1/4" plate.That's the way I would do it.
Old May 1, 2007 | 05:16 PM
rickfixit's Avatar
rickfixit
What's the best way to cut it and keep everything straight.
Old May 1, 2007 | 05:31 PM
Marz-68's Avatar
Marz-68
I would cut right behinde the cab but first I would run a few cross bars on top and under the frame so that when you cut it it will all stay square, then mark the lines on the frame were you want to cut it and start cutting.
To cut the frame I would use a grinder with a cutting wheel, this will give you a clean cut so that when you weld it all back together the pieces will but up nic and straight. Then cut some 1/4" plates and weld them over your welds to renforce that section of the frame. Good luck with your project.
Old May 1, 2007 | 08:46 PM
67Pustomp's Avatar
67Pustomp
I have used a portable bandsaw for such an application. They can be found at rent it centers. You can also clamp angle iron to the frame to be used as a guide for the running of a sawsall.
Old May 2, 2007 | 01:03 AM
arctic y block
I cut my frames on an angle (/) like that. than weld it and put an insert inside that fits the frame tight all the way around and bolt it in. It takes the strain off the weld and will never crack. On big rigs you must do this to pass DOT. Anything less I think is unsafe. JMHO Plate welding will weaken the frame at every weld.
Boss9F100
Jan 2, 2014 11:31 AM
broncojames
Car/truck Buying Advice
Jul 13, 2010 03:03 PM
wopicetti
May 27, 2005 09:01 AM
Superfarmer 250
Aug 12, 2003 10:58 PM
1970f2504x4
Jul 27, 2000 03:39 PM
