Sponsored by: Auxito
Brights/Dim Switch
Old Oct 7, 2002 | 10:31 AM
PaulC's Avatar
PaulC
Brights/Dim Switch
Old Oct 23, 2002 | 04:49 PM
mpiorko's Avatar
mpiorko
Brights/Dim Switch
About a year ago I was driving home at night in my '97 E150 and noticed that my headlights weren't on. The headlight switch was pulled out, and I didn't think both headlights went out at the same time, so I started tinkering. I found that they went on when I pulled the turn signal lever, (like when you flash your lights), so I knew they worked. When I flipped the lever for brights, they went on. I pulled the steering column apart; it appears like the switch is all one unit with the turn signal lever. I figured the switch is bad, so I cut the wire for the regular headlights and rewired it to the brights end of the switch. It worked great, although I no longer had brights. A couple days ago, I started to have the same problem again. So far, if I keep flipping the lever from brights to regular, eventually the headlights work, but I know I'm gonna be 100 miles from home at midnite and it's not gonna work. The headlights will go on when I pull the lever. I assume the switch is finally giving out completely. Can I replace just the switch, or is it all one unit with the turn signal lever? Does anybody know the part number? Please reply asap, 'cuz I know this thing is gonna die altogether any day now. Thanks for any and all help.
Mike
Old Oct 24, 2002 | 10:11 AM
ralphie123's Avatar
ralphie123
Brights/Dim Switch
The turn signal/wiper/highbeam switch is a combination unit. The one in my '96 F53 chassis motor home appears to be similar to the one in my 2002 F150, and may be similar to yours. The switch caused wiper problems in my motor home. I got the switch from Ford for about $75. It was very easy to replace. You need to pry out the ignition key flange, remove a few screws (torx) from under the steering wheel covers, and two screws that attach the switch to the column, plus two wiring plugs. I suppose it's possible that your light switch is causing the problem, but I don't have any suggestions for that.
