Sponsored by: Real Truck
Need HYD clutch help.
Old Apr 25, 2007 | 08:33 PM
carrcreekcaller's Avatar
carrcreekcaller
Im having the same problems as this thread https://www.ford-trucks.com/forums/6...tch-issue.html
1. How do you remove the pin attaching the clutch pedal to the rod for the master cylinder.
2. Is it neccesary to remove/replace the switch on the clutch pedal - whats the switch for?
Thanks, CCC
