Allright, I've never gone through and ordered a set of full custom pistons, so I have a quick question. I know I can order them with however deep or shallow of a dish I want, but is there a manufacturer out there that will cut the dish to the exact shape I want, like a mirror dish?
If not I'd be better off buying a set of off the shelf TRW flat tops and then send them off to a shop with autocad files of how i wanted the dishes cut.
Justin
Having not ordered a set of custom pistons before I couldn't tell you. I've come close to ordering a set, but always found what I needed in stock form. I would advise you to contact Ross pistons here:
I know they aren't cheap, i've looked into a couple sets and all of the piston manufacturers want around $800-$900 a set.
That's why depending on if i could get exactly what i want or not from a manufacturer i may be better off buy the off the shelves and getting them modified.
