Zoodad mod question
Old Apr 25, 2007 | 02:29 PM
MikeSDK's Avatar
MikeSDK
Zoodad mod question
I looked in the common mods thread, but did not find what I was looking for.
Is the Zoodad mod done to the stock air box, or the AIS airbox?
Secondly, if you do it to the AIS airbox, do you also do the fendersleeve, or is it one or the other?
If someone has some pics of this in their gallery, I'd like to take a look...
Thanks
Old Apr 25, 2007 | 02:32 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
A zoodad mod is an enlargement of the air opening in the front bulkhead behind the grill. The stock opening is small and doesn't allow for a lot of airflow to the intake. You can do it with a stock box.
Last edited by ryaneverk2; Apr 26, 2007 at 03:21 AM. Reason: removed bad image link
Old Apr 25, 2007 | 03:37 PM
mongo75's Avatar
mongo75
You can use a dremel tool, or start by drilling holes in the corners and then sawing between them. After you make the hole, sand the edges smooth. I also took some duct tape (go figure) to make a duct between the hole and the intake tube box thing next to the battery. You'll notice a lot more dead bugs on your filter!!
Old Apr 25, 2007 | 03:58 PM
F250_'s Avatar
F250_
Originally Posted by mongo75
... You'll notice a lot more dead bugs on your filter!!
Just one good reason to install a prefilter dust cover like mine in my avatar.
Old Apr 25, 2007 | 05:37 PM
MikeSDK's Avatar
MikeSDK
Thanks guys-
Old Apr 25, 2007 | 09:42 PM
MTDewX's Avatar
MTDewX
I got the preadator grill that funels the air right in. and helps stop a few of the bugs. cleans up the hole you make for the fresh air. I did not so the fender sleeve. I also have AIS which is similar to the stock box, just better filtration
Old Apr 25, 2007 | 10:22 PM
mongo75's Avatar
mongo75
Hey, what is the AIS airbox?? Call me dumb....
Old Apr 25, 2007 | 10:49 PM
schwengler's Avatar
schwengler
It's a bigger air box to accomadate the bigger air filter.
Ray
2002 F250 4x4, AIS,4"exhaust,superchip
Old Apr 26, 2007 | 07:20 AM
mueckster's Avatar
mueckster
The AIS is a revised air filter box that uses a Donaldson filter. I believe the trade name for the filter is "Power Core", which has a swirl-type shape to the element.
