my 02 f50 overheats fairly regularly. generally when the ambient temp is above 95 degrees. doesn't seem to matter whether it is under load or not. and of course, the truck never overheats when i take it in to the service department. they say that they have done flow tests, bock tests and called detroit for help, but cannont seem to find the problem. the truck has less that 23000 miles on it. any suggestions other than lemon law. i've got about 3000 into the truck and don't wnat to have to pull all my accessories
I'm sure you probably already checked this, but are you actually seeing signs of overheating. Maybe it's just the sending unit or gauge. Did you say the fan clutch is working. Good luck.
thermostat has been replaced, didn't help. one of th ebelts squeks under hard acceleration, although i think it may have more to do with the a/c.
as far as signs of overheating, i had a digital thermometer wired into the radiator hose, temp got as high as 262.
When does it overheat?
If it runs cool at highway speeds, then your radiator, thermostat, and water pump are functioning properly.
If it overheats at low speeds and /or idle, then suspect the fan.
Good luck!
Bru
2002 F150 Super Crew
Black 4X4 Lariat
5.4 Engine Ford Chrome Bars
Ford Bedliner
[updated:LAST EDITED ON 24-Oct-02 AT 11:50 AM (EST)]I recall that some 4.6 Crown Vic's had a problem in that the water pump impeller was loose on it's shaft. The fan belt would turn the shaft, but the impeller would either turn at a much slower speed, or not at all. This problem did not occur all the time on an afflicted car, but when it did, no coolant circulation.
P.S.: Repeatedly frying an engine that contains aluminum components is a very bad idea. Get more aggressive about finding out the problem.
I'm having a very similiar problem with 2002 f150, it overheats at highway speeds when the outside temperature is above 85 degrees. The water pump, thermostate, and radiator flush have all been replaced and the problem has persisted. The truck does not overheat at low speeds or while idling. To keep the truck from overheating I can turn on the defrost which alleviates the issue. It has been looked at by two different ford dealerships and the problem has not been discovered. Any help would be greatly appreciated!
This is an old thread …however stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Turning on the defrost engages both the heater and the a/c at the same time. It's the heater coil that's giving you some extra cooling. It sounds to me like the thermostat, or a blockage in the system somewhere.
if the tranny is an automatic, look at tranny temps. A cooler line that runs through a radiator will overheat the engine if the tranny is running excessively hot. Found this out while mud running rigs with "autotragics" in the mountians here. Either figure out trans temps, or switch to a purley external tranny cooler (eliminate it comepletely from the radiator)
look at recent thread about 97 f150 overheat then cool again. my 03 is doing the same thing and ford is replacing the heads, head gaskets, intake manifold gasket and spark plugs. seems the head gaskets were bad. it must be a common problem because ive been waiting three weeks for heads- one set came in but they were bare heads and they had ordered assembled heads. ive heard that you can pull the spark plugs and look for coolant on them- that is what finally got them going in the right direction with my truck.
