Sponsored by: Real Truck
Odometer Rollback??
Old Apr 25, 2007 | 12:07 PM
10banger's Avatar
10banger
Odometer Rollback??
I'm looking at a 2000 F-350 but the mileage on it seems to be a little low for what they owner used it for. It has 64K miles on it, and CarFax does not report an odometer rollback. However he NEVER had dealer service on it and tells me he did all his maintenance himself. He owns a shop so I don't doubt that. However, a mutual friend said he drove the heck out of the truck and there's no way it only has 64K miles. The guy has a good reputation but if the odometer can be rolled back, I'm sure he could do it.
<O
My questions are: can the analog odometer on that truck be rolled back, and if so, can it be detected in any way? If so, I'd like to be in the know so I can check it out. <O</O
<O</O
Thanks for any help...<O</O
Old Apr 25, 2007 | 12:35 PM
msgtg's Avatar
msgtg
Good question. Mine has a digital so I'm not much help. I know you could on the older models but never had a 2000.
Old Apr 25, 2007 | 12:44 PM
Carpainter29's Avatar
Carpainter29
I think the cluster can be changed out pretty easily.................
Old Apr 25, 2007 | 01:41 PM
texcan's Avatar
texcan
If it is a standard then you can unplug the speed sensor! I have friends that do this on the dodges. It will not work with the autos though as they will not shift right.
Old Apr 25, 2007 | 02:05 PM
juterbock's Avatar
juterbock
The other option is someone dismantled the head and rolled the numbers back, if you look really close sometimes the numbers don't look properly aligned if they have been rolled back.
Old Apr 25, 2007 | 02:08 PM
Lonewolftx's Avatar
Lonewolftx
Smile
<O
<O</O
If you are that concerned then move on to another truck.
Old Apr 25, 2007 | 05:03 PM
MobeyDick's Avatar
MobeyDick
It can be rolled back and you can't tell by the numbers in the dash from the seat. You might be able to tell if you took out the dash cluster. See If they tore the frail plastic strip. Other then that how does the steering wheel look. It only cost about $210.00 to replace that but the Dye will be worn a good bit at 65K and it will be slick. Brake petal will have some wear as well the Seat and the Floor mat on the drives side. Look around the Starter Switch, I leave a single key in mine so it don't get scratched but most people don't it should look worn. Look at the driver side door handle inside and outside should have some but not a lot of scratches inside should show some wear but not a lot!
Old Apr 26, 2007 | 12:41 AM
LaredoF350's Avatar
LaredoF350
When i read this, I cant help but get the impression that you are fishing for info on how to do a rollback! If not, I apologize but its just my gut feeling.
Old Apr 26, 2007 | 12:57 AM
RACERX7775's Avatar
RACERX7775
i would suggest to forget about this truck if you have your doubts. if you cant ever tell, you will never be happy with it always wondering if it was rolled back. and the numbers dont always line up anyway. my X odometer has never really lined up perfectly since new. it now has 90,000.
Old Apr 26, 2007 | 01:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Newer speedos have a glop of plastic where the odometer mounts into the speedo head. If the plastic is broken off, the odometer has been tampered with. Someone could also remove the speedometer cable driven gear, hook the cable back up and drive the vehicle for years without any ill effect. The speedo won't work, but no miles will be recorded either. Point of fact: 40 years ago, when tampering with odometers was a way of life to car dealers, odometers weren't rolled back, they were rolled ahead. One way the gov't stopped that BS was having a 6 digit odometer, back then it was only 5 plus the tenth of a mile.
There is a Federal Law that states if a speedometer has been replaced for any reason, a sticker must be placed on the door or B pillar. The sticker will have the date of repair and the mileage on it. It may be gone, but y'all might check anyway.
Have you run an Oasis report?
Old Apr 26, 2007 | 03:33 AM
Cowboy Brett's Avatar
Cowboy Brett
Ford's been using electronic clusters for some time now, at least since the mid 1990s. Even the ones with analog odometers are really electronic. They have an electric motor that rolls the numbers over.
I will tell you that replacing the instrument cluster generates quite a paper trail. When my speedometer (but bizarrely not my odometer) took a dump on my 98 F150 and I went to Ford to get a new one, I had to fill out a lengthy form. The new cluster came with the number of miles on my truck, which you had to fill out on the report and sign for under penalty of law as described above.
Old Apr 26, 2007 | 05:51 AM
tjmax7668's Avatar
tjmax7668
Mileage can be retrieved through the pcm, digital or analog.
Old Apr 26, 2007 | 05:54 AM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
Dash cluster/speedo picked up at a junkyard?
Old Apr 26, 2007 | 08:43 AM
Biggziff's Avatar
Biggziff
You can buy a cluster on ebay or buy a reprogrammer that will let you change the miles to whatever you want. There are people out there that sell this "service" as well. Many take no responsibility for what mileage you tell them to put on the cluster.
http://www.dashboardprogramming.com/english.php
Bottomline is, if you're suspect of it, back away. Mileage can be changed easily on any vehicle.
Old Apr 26, 2007 | 09:05 AM
2002 F350V10's Avatar
2002 F350V10
rebuilders use a service which you send in the speedo cluster and you basically state the miles you want and they do it. uses a pc with an adapter harness which connects the printer port to the speedo cluster. ive seen it done before.
