Extra lights
Old Apr 24, 2007 | 10:16 PM
luke245's Avatar
luke245
Extra lights
How hard would it be to install 2 more off-road lights to my bull guard and put them on the same circuit as the headlights? So when I pull my headlight switch the 2 extra lights will also turn on?
Old Apr 24, 2007 | 10:24 PM
frederic's Avatar
frederic
I wouldn't put any lighting on the headlight circuits directly.
What I would do is put relays on the headlight circuits, which draw very little, and use the contacts of the relay to connect the new lights to the battery through an appropriately sized fuse.
This way, if the lights get broken, short, or the wiring goes bad, your headlight fuse won't pop and leave you with no lights at all.
Also, direct wiring to the battery also gives you more current than going through the thin harness wires that you'd be overloading.
Hot wires resist current more, then get hotter, and resist current more, and this continues until the overloaded wire burns up. Assuming the fuse doesn't pop first, which of course you'd prefer.
tvannaman2000
Sep 21, 2014 04:10 PM
stock95
Sep 18, 2011 11:17 PM
TAT2DUP81
Feb 24, 2011 12:22 PM
bghnkinf250
15
Jan 19, 2010 12:35 AM
shand32783
Dec 31, 2003 03:48 AM
