Paint peeling off
Old Apr 24, 2007 | 09:37 PM
NorthCarolinaExpy's Avatar
NorthCarolinaExpy
Paint peeling off
My rear roof luggage rack has completely lost its black paint covering. It is the cross beam that connects one side to the other. Now it's a shiny aluminum going down the road. Does anyone know how I can paint this black again since it's aluminum? Would it be better to buy that piece at a salvage yard rather than try to repaint it?
Your input on this will be greatly appreciated.
I have taken it off the top and it appears to have 2 torx screws on each side holding it in place. Removing these torx should let me take the piece out for painting or replacement.
Old Apr 24, 2007 | 10:38 PM
aagitch's Avatar
aagitch
If it was me I would replace it.
Old Apr 25, 2007 | 12:10 PM
RAGaz's Avatar
RAGaz
I have the same problem just on the cross bars on my '01 Expy. I'm planning on cleaning, priming and painting them this summer.
Old Oct 24, 2011 | 11:52 AM
silentstkr's Avatar
silentstkr
Question Same problem on my 2002 Explorer
Does anyone know what kind of spray paint to use on the rack?
Please advise,
Thanks
Old Oct 24, 2011 | 10:45 PM
Moto Mel's Avatar
Moto Mel
An etching primer should do the job, just be sure to follow the instructions regarding preparation and you will get a job well done.
Old Oct 25, 2011 | 09:18 AM
BAD RONALD's Avatar
BAD RONALD
Had the same problem with my '01. I slid them off, removed the ends and scuffed the cross bars clean. These are aluminum and need to be done with steel wool or scotchbrite pad. Cleaned 'em with rubbing alcohol. I gave them each two coats of black bed liner since I figured it was rooftop carrier contact that caused the condition. Tough material that bed liner and it looks good. I think I paid less than ten bucks for a spray can at Napa.
Old Nov 10, 2011 | 08:18 AM
944_s_type's Avatar
944_s_type
I will have to agree. I am an aircraft mechanic. Most all our parts are alu. It must be Stripped, etched, primed and painted. Do it right, and you will never have to touch it again.
Old Nov 10, 2011 | 09:07 AM
BAD RONALD's Avatar
BAD RONALD
When I was in line at Napa buying the bedliner spray it was a Sikorsky aircraft tech who put me on the steel wool or scotch brite pad sanding. The guy said that regular sandpaper would foul up the adhesion of the paint. Nice of him to set me straight. I only wish he was around when the aluminum hood on my truck was painted at the factory. If there ever was a lousy prep/paint job done to aluminum it happened with these vehicles.
Old Nov 13, 2011 | 02:26 PM
68bluebeast's Avatar
68bluebeast
I have the same problem on my 01 navigator, I am thinking about stripping them down and then prime and painting them with duplicolor engine paint to fight the hot sun.
David Watson707
22
Jul 10, 2018 09:45 PM
abe
Feb 21, 2017 09:58 AM
Matt1966
Feb 19, 2017 04:22 AM
Agro
Feb 10, 2017 09:25 PM
jbourne84
Feb 9, 2016 07:57 AM
