Modular V10 (6.8l)
V10 running like crap need help
Old May 12, 2007 | 06:51 PM
exposition's Avatar
exposition
Tell me how you test the coil packs so I can do it ,please .
Thank You .
Old May 12, 2007 | 08:48 PM
automike25's Avatar
automike25
Once you pull the electrical connector off of the coil pack you will see two metal pins. Put one of the test leads from your multimeter on one pin and the other test lead on the remaining pin and the resistance between the two should be about 0.3 - 1 ohm. If you find an open or the resistance is way off then it is supposed to indicate a bad coil pack. I also had my coil packs unhooked from the plugs and completely off of the truck but I dont know if that matters or not. hope that helps
Old May 13, 2007 | 12:39 PM
exposition's Avatar
exposition
Automike ,Thanks for the reply on the coilpack ohm's test . I've been wondering about this since I got My X .
Old May 14, 2007 | 08:20 AM
Fredvon4's Avatar
Fredvon4
idles fine with no miss in park is what I am reading....is this correct?
Old May 14, 2007 | 10:35 AM
Big Orn's Avatar
Big Orn
Originally Posted by automike25
Is it possible that one could be bad even though the resistance between the pins meets spec?
Yes. The COPs could spike - High/Low - and "show" to be within specs at the time. You really need to check the COP's resistance. Sometimes the only way to check them is under load with a Worldwide Diagnostic System - usually done at the dealer...but worth it. Depending on your PR with the dealer, it could cost anywhere from $50 to $125 just to find it.
Old Jun 5, 2007 | 04:09 PM
Camperdaddy's Avatar
Camperdaddy
AutoMike25, it's been awhile....any details? Mine was acting similarly. How's yours accelerate? Does it sputter at all?
Old Jun 5, 2007 | 04:19 PM
Camperdaddy
Ahhh, the wonders of the search function. Change a word and Voila! This'll probably fix mine.
To quote JLangton -"Have you ever changed the spark plugs? I purchased my '98 model with 107K miles on it,and on the test drive it was weak,and would stutter under heavy throttle.Changed the spark plugs(they were the originals),and it ran great after that.Honestly I dunno how it was running before I changed them-there was a .080" gap or more on every plug.
JL"
This sounds exactly like what's eatin' mine. Now off to find the spark plug brand threads.......
Smokey_7.3
16
Aug 23, 2014 12:58 AM
Egghead86
Jun 13, 2014 09:17 PM
6.0techwannabe
May 8, 2012 03:25 PM
4CFarms
Aug 27, 2011 07:48 PM
