Fuel filter drain valve question??
Old Oct 8, 2012 | 05:04 PM
twom7's Avatar
twom7
I got up this morning and there was a diesel puddle under my truck, so I crawl under and take a look and the fuel was draining out of a tude on the passenger side of the engine and I traced it back to the back of the fuel filter. I called a PSD mechanic buddy and he said when you start getting cold temp. snaps that the o-rings shrink up and this causes the o-rings to fail which causes fuel to drain out of the tube. My question is what causes this is it just the o-rings, and can I just replace the o-rings?? I checked with Ford parts and they want $68 for a fuel filter drain valve. Also, how often do these drain valves go bad?? Any feedback is much appreciated.
Old Oct 8, 2012 | 05:16 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Replace the orings with the blue Flourosilicone orings from DieselOrings.com
How To: Fuel Bowl Rebuild - 7.3L Powerstroke - YouTube
Old Oct 8, 2012 | 05:18 PM
F250_'s Avatar
F250_
If you can wait for a shipment, I would order from Bob at DieselOrings. His price for an upgraded o-ring kit (best available) is only $19.50 + S&H and includes every oring and seal necessary to completely reseal the entire fuel bowl.
Here is a link to that kit on his site, and make sure to select the option for the Blue orings which are the best material available.
#7-003 Fuel Bowl Reseal Kit 1999-2003 - Fuel Bowl Parts and O-rings - 1999-2003 Ford 7.3L
Old Oct 8, 2012 | 05:19 PM
F250_'s Avatar
F250_
Now how's THAT for fast response with real answers AND instructions on how to do the job?!!... and save you nearly $50 to boot??!!
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I think we pretty much covered it
Old Oct 8, 2012 | 05:22 PM
F250_'s Avatar
F250_
You betcha!!
Old Oct 8, 2012 | 05:34 PM
twom7's Avatar
twom7
Dadgum you guys are fast...
I will order those o-rings from that o-ring guy. Many thanks for the video link...you guys are spot on in helping me fix my problem. I really appreciate the quick help and thanks in advance.
Old Oct 8, 2012 | 05:37 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Its what we do
Old Oct 8, 2012 | 05:38 PM
F250_'s Avatar
F250_
Hey, you should also know that Bob (DieselOrings) is one of us, and is simply AWESOME to work with. He also has a nice selection of other OEM supplies at much-better-than-dealer prices, as well as a whole slew of installation instructions for mods/repairs.
Old Oct 8, 2012 | 05:39 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
You forgot to mention super quick shipping, and fast email tech support, even on Sundays!
Old Oct 8, 2012 | 06:08 PM
SteveH-CO's Avatar
SteveH-CO
Yes - Bob is the man - got me just the valve o-rings very quickly - shipped just hours after I placed the order.
Old Oct 8, 2012 | 08:07 PM
twom7's Avatar
twom7
Placed an order with Bob at Diesel o-rings...
Thanks for all the help and guiding me off in the right direction. I placed an order for o-rings and fuel filters. Thanks in advance for sending me off in the right direction.
Old Oct 10, 2012 | 07:35 AM
Brother Les's Avatar
Brother Les
I saw your post on the other thread. Looks like you are well on your way with the help of The Brotherhood. Did Bob (Guzzle) talk to you about overhauling the whole fuel bowl (cheap but grade AAA parts)? It should be done, only takes a couple of hours if your don't know what you are doing and a half hour it you do...... (along with either 6 or 3 beers )
Welcome to the Ford Truck Enthusiasts Forum and the Brotherhood.
Old Oct 10, 2012 | 09:35 AM
spongecop's Avatar
spongecop
Semper Fi
I figured it was ok to hijack this thread with a question since OP questions were taken care of... I recently rebuilt my fuel bowl and my hard line drain tube is clogged. I have tried compressed air, brake cleaner you name it and cannot get it un clogged. cant remove it cause its routed under the HPOP reservoir. Any suggestions other than running a piece of fuel line parallel until I have to do HPOP work on day?
Old Oct 10, 2012 | 09:52 AM
F250_'s Avatar
F250_
You can try the same thing recommended for cleaning out the EBPV tube... get a heavy gauge piece of weedeater string which is not round, insert one end into a drill, and try to guide it downwards through the tube while spinning it with the drill. I would suggest using a piece of steel cable, but there is a good chance that the spinning end of the cable might just grind through the tube sidewall which will not and cannot happen with the plastic weedeater string.
One other option might be to get a piece of copper ground wire (like a #12) from a piece of house wiring and try snaking it through the tubing by hand. The copper is flexible enough to bend with the tubing, and the #12 is still stiff enough to not try to double up on you inside the tubing.
Hope this helps.
