Sponsored by: Real Truck
light conversion !
Old Apr 23, 2007 | 10:29 PM
BigJ5656's Avatar
BigJ5656
light conversion !
hey guys, i was wondering about doing a light conversion on a 2003 ford f250 XL .... its got the actual full glass bulb and i wanted to convert it to the plastic style lens .... does anyone know how i would go about doing this ? or have a guide or some kinda parts list ? thanks
Old Apr 24, 2007 | 11:46 AM
msgtg's Avatar
msgtg
Hmmm, I've got an 03 King Ranch. Since I haven't paid any attention to the XLs, I ASSUME (yup, there's that word again) that if the two lenses are the same dimensions, it would be a simple 'plug & play'.
I'll have to look closely at mine now.
Old Apr 24, 2007 | 11:48 AM
Storm's Avatar
Storm
Are you referring to the Commerical style? With the old style rectangle lights? If so then you'd need a new Front Face Plate for the newer style and the headlights..
Old Apr 24, 2007 | 12:08 PM
BigJ5656's Avatar
BigJ5656
yeah, its got the rectangle plastic plate, with a full glass bulb, vs, say the one that you have on your truck ! i mean, can i not just buy : the lens, bulbs, and then somehow rewire the connections to the other
Old Apr 24, 2007 | 12:13 PM
Storm's Avatar
Storm
You can but they won't mount to the face plate or the back plate.. If I'm thinking correctly the headlight mounting bracket is different then the one for your lights. You would have to replace the mounting bracket, the face plate, lenses, bulbs, and rewire.. Best bet is to hit a junkyard and find a wrecked SD with a good front end and do that..
Old Apr 24, 2007 | 12:15 PM
BigJ5656's Avatar
BigJ5656
hmmmm good call on that ! then maybe i could just replace my grill too :P BUT do i have to stay in the 99-2004 range before they changed the style a bit ? or can i go rigth up to 06 you think ?
Old Apr 24, 2007 | 12:20 PM
Storm's Avatar
Storm
Hmm.. I believe you can.. But you would need the entire front end clip.. Because the 06 grills were larger then the 04 and below.. For instance in order for me to use a true 05+ Grill I would have to trim the grill to fit.. So pretty much yes I would say if you could find an 05+ in a junkyard with the front enter good.. Snag the whole front clip and you could swap it out..
Old Apr 24, 2007 | 12:33 PM
wiingnut's Avatar
wiingnut
I have an aquaintance who did what your asking about and if memory serves correctly he had to replace the whole front end clip like Storm said
Old Apr 24, 2007 | 12:34 PM
BigJ5656's Avatar
BigJ5656
like they say, if theres a will, theres a way ! just depends on how much $$ you wanna spend :P haha
Old Apr 24, 2007 | 12:36 PM
Storm's Avatar
Storm
You'd be suprised.. Clips are pretty cheap in junk yards.. They aren't as crazy as some folks.. They just want the cars outta there.. Me and a buddy went in once and snag the entire cab of an F150 for $100 bucks.. It was just getting it off and out of there lol..
Old Apr 24, 2007 | 12:38 PM
BigJ5656's Avatar
BigJ5656
hmmmmm, portable plasma cutter time now that the weather is nice out,ill have to check it out .... with my luck, they are all front end collisions lol
