Block prep for a stroker
Old Apr 23, 2007 | 07:07 PM
bhardy501's Avatar
bhardy501
If I built a 514 stroker will a stockblock work or will I have to do some clearencing on the nlock to get every thing to turn without hiting anything? Also does anybody know about the stroker kits offered on EBay? They advertise mosty Eagle rods and cranks with name brand bearings and such.
Old Apr 23, 2007 | 08:51 PM
backwoodspuller's Avatar
backwoodspuller
a stock block will work fine
as far as ebay kits i cant vouch for them but eagle from what i know is good stuff i know scatt also makes differnt stroker kits but i gotta ask why 514?
for the same cash you can go bigger i run a scatt 501 kit but i have a cube limit in my class but if i didnt have that i would go as big as possible but i havent heard of a stock block going over a 572?
if you want to know about some good parts supplyers me privet message me
Old Apr 23, 2007 | 11:18 PM
bhardy501's Avatar
bhardy501
Thanks for the info. I was considering the 514 instead of bigger so I would have room to go bigger in the event of something breaking, maybe I would still have a little room left to grow.
Old Apr 25, 2007 | 12:47 PM
MychalCrowson's Avatar
MychalCrowson
well if something broke you'd be in the same spot whether you went with the 514's 4.3" crank and say a 545's 4.5 " crank. the only thing that will stop you from being able to go bigger is if you bore the thing out to 080 right off the bat, if you do a standard bore or 030 you will have room to work with still once you decide to tare down again. I would also recommend the 4.5" stroker crank as well same money
