1978 - 1996 Big Bronco
A Few Questions
Old Sep 12, 2001 | 08:44 PM
bronco_master's Avatar
bronco_master
A Few Questions
first of does any body know the stock hp and torque of a stock bronco, 351, e4od trans.? Also who make a great pair of headers for the bronco? is the K&N FIPK worth the 150$?
Old Sep 12, 2001 | 09:46 PM
bronco_master
A Few Questions
thought a one more, does anybody know where i can get the body piece under the headlights and grill?
Old Sep 12, 2001 | 09:48 PM
DeGideo's Avatar
DeGideo
A Few Questions
I'm not sure what the 351 2-V& 351 4-V engines were rated at,but the EFI351s started out(1988) with 190-200 horsepower.The 1995 Bronco brochure lists the 351 as having 210@3,600 rpm&325lbs./ft.@2.800 rpm.The 1996 brochure lists the 351 as having 205@3,500 rpm&328lbs./ft.@2,200 rpm.As for 5.8L headers offered....there are soooo many companies that offer them,I can't remember them all! Get a set of stainless steel versions-they cost more,but will last longer.The F.I.P.K. K&N filter is worth the money.You'll see a nice difference.To get the most out of it,add headers and dual exhaust.Don't go overboard on the diameter size,unless you plan other upgrades.A 2 1/4",or 2 1/2" system will give the best results.
Old Sep 14, 2001 | 01:12 AM
Riso79's Avatar
Riso79
A Few Questions
I am not sure what the Horsepower is for the Bronco, I have a '93, 351 with E40D and would love to have the ratings.
A great set of headers for the truck are made by JBA, or Gibson, they're the same thing. From what I found, JBA makes them for Gibson. They are awesome! They add to the torque and make the truck sound sweet. But they're not cheap. I started out with the K&N filter kit that sits in the engine bay and replaces the whole factory filter assembly. The K&N is awesome and really helps throttle responce but it is noisy as hell. More noisy than the exhaust. I had to buy just a replacement filter for the factory box. It gave me almost the same effect without the added noise. The noise is cool around town but on long trips I put the factory back in.
Old Sep 16, 2001 | 03:25 PM
DeGideo's Avatar
DeGideo
A Few Questions
The 1993 5.8L V-8 was rated at 200@3,800rpm & 310 lbs./ft. of torque at 2,800rpm.
Old Sep 16, 2001 | 11:41 PM
hickmo's Avatar
hickmo
A Few Questions
