Transmisson!!
Old Apr 22, 2007 | 11:30 PM
emain879's Avatar
emain879
Cool Transmisson!!
I have a 97 powerstroke automatic and the overdrive light keeps blinking and it wont shift into overdrive or shift you have to do it manually? what is the problem
Old Apr 23, 2007 | 12:06 AM
97REDPSD's Avatar
97REDPSD
If I was you I would pull the codes first and post them. Here or transmission forums. There are alot of smart people here that can help you out. but you need to get codes first. good starting point.
Old Apr 23, 2007 | 07:33 AM
tjbeggs's Avatar
tjbeggs
yep codes will be needed. most likely the Vehicle speed sensor on the rear diff. is bad or has a bad connection. you can check the connection first. make sure its clean and wires look to be in good shape.
Old Apr 23, 2007 | 08:23 AM
emain879's Avatar
emain879
Cool Transmissio!
i did it this morning my edge was gettin p 1748 no idea it doesnt know what that is. Transmission Fluid TEmp sensor p1728. and tranny slip. help! lol
