speed sensor removal
Old Apr 22, 2007 | 03:04 PM
jcs1966's Avatar
jcs1966
i posted earlier with my problems and did some research and want to remove the VSS from my 1996 F150 SC 4WD rearend to see if the 1.speedometer works 2. check engine light goes off 3. ABS light goes off 4. O/D light stopps blinking.
i was under today and how do you remove it? the rearend seems like it has walls to protect it.
Old Apr 22, 2007 | 03:36 PM
subford's Avatar
subford
1. Remove bolt. Remove rear brake anti-lock sensor (2C190).
2. Clean axle mounting surface, using caution to prevent dirt from entering rear axle housing (4010).
3. Observe if axle lubricant has leaked up through core or around perimeter of rear brake anti-lock sensor O-ring. Discard if leakage is present.
Old Apr 22, 2007 | 08:53 PM
alz's Avatar
alz
When I replaced mine, half was stuck inside the diff. I needed to use needle nose pliers to remove. The originals are made of some thin metal. The one I replaced with from Ford was a solid plastic piece and much sturdier.
chefjb98
Apr 14, 2011 03:18 PM
Allamand
2004 - 2008 F150
May 28, 2010 01:06 PM
broboon525
Jan 24, 2010 01:26 PM
TN615
Jan 17, 2009 07:34 AM
trouble61
Jul 22, 2004 11:17 AM
