Changed Coolant, Strange Temp Guage Activity
Old Apr 22, 2007 | 02:24 AM
grantorino's Avatar
grantorino
I have a '97 F350 CC 4x4 (if anyone can quickly tell me where I set up a signature on this site I'd do it)
So I replaced my upper, lower and degas radiator hoses, drained the cooling system (including the two back block plugs), flushed with the prestone kit. I put plain old Fleetguard back in mixed 50/50 with distilled H20. Also mixed in a pint of DCA4, which I assume I'll need to add more of, but want to test with strips before I go too nuts with it.
Anyway, I take it for a test drive. Everything looks good, no leaks or anything. I pull over after a couple miles and everything still looked good, degas bottle level hadn't changed either. Drove some more at around 45 MPH for a few minutes and noticed my dummy temp gauge creeping higher than I'd ever seen it. Started getting freaked out a little when the needle hit the "A" and pulled over to check things out. Everything looked good, but the degas bottle level had dropped a good bit. I cracked the Prestone flush kit T and the degas bottle, closed them and jumped back in.
All of a sudden the temp guage went back down to where it usually sits, around the N and it stayed there for the rest of my travels (about 20 min).
Was it just a weird bubble or something that caused the guage to go up so much? Just curious.
Thanks!
Old Apr 22, 2007 | 06:23 AM
Cuda_jim's Avatar
Cuda_jim
Yep, just a bubble, Sounds normal, I takes a while for the thermostat opening. Once open it 'burps' the system and you see a drop in the de-gas bottle. You should be go to go now.
Old Apr 22, 2007 | 11:21 AM
BadDogPSD's Avatar
BadDogPSD
Thumbs up
Just click on User CP in the blue tool bar above the forum. I think you have to have a minimum of 25 posts (which you have now) before you can add a sig.
Stewart_H
548
Jul 6, 2025 12:14 PM
Jesser02EX
26
Jul 6, 2014 03:33 PM
adammdennis11
Jun 27, 2014 10:42 PM
dirtriderdan
Nov 23, 2009 09:30 AM
BLK94F150
1997 - 2003 F150
Apr 26, 2009 02:43 PM
