starter solenoid???
Old May 1, 2007 | 02:32 PM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by travis dasher
Yeah it is the starter. When I do the screwdriver test I can hear a click. I will be replacing the starter this week.
Yeah I was going to say that I think the bendix might be binding up and you just need to get a whole new starter.
Old May 2, 2007 | 02:35 AM
travis dasher's Avatar
travis dasher
Thanks for the help guys. Priced some starters at NAPA $250-$400. I haven't priced the one's from the Stealer yet. Maybe I wont now that I know NAPA's are this much. Oh well.
Old May 2, 2007 | 02:48 AM
wocker's Avatar
wocker
mine was exactly the same i fitted a relay to the starter and not one problem since.previous owner changed the starter from a clacker type to a solanoid type and you get a voltage drop when cranking without the relay
Old May 2, 2007 | 12:14 PM
abvoitik's Avatar
abvoitik
I've been having a similar problem on an '02 7.3L. I turn the key and instruments come alive but the truck won't crank, Im not hearing a click though. Thwe batteries checked good with a voltmeter. Could you explain a little more about "jumping" from the posts with a screwdriver to bypass the solenoid. I just put a Napa starter in 6 weeks ago that had the solenoid attached. I currently have the starter out and I'm on my way back to Napa to have them bench test the starter. If they say it's good what's next?
Old May 2, 2007 | 12:39 PM
travis dasher
If the starter is good then check the coil on the passenger side fender or fire wall. That could be going bad. If it is bad go with OEM parts on this TRUST me you dont want the headache I have been having. I went with a coil from the local auto parts store and all 3 were defective.
To jump from the post you turn the key wait for the wait to start light to extinguish go to the starting coil on the fender or fire wall disconnect the small wire from its post and lay a screwdriver across the 2 brass posts. If it makes a click then starts like mine is doing then the starter is going bad and NTB replaced.
WELCOME TO FTE
Old May 2, 2007 | 12:45 PM
zx250's Avatar
zx250
Of the next Riffraff East
.......If it makes a click then starts like mine is doing then the starter is going bad and NTB replaced.
WELCOME TO FTE
Travis, is this what you meant to say? If jumping the solenoid allows the starter to spin and start the engine, then that points to a good starter and bad solenoid. If jumping the post only gets you a click, the the starter has problems. Right???
Old May 2, 2007 | 05:32 PM
abvoitik's Avatar
abvoitik
Just got back and the starter and solenoid are fine, what now? Batteries, Fuses, relays and fusible links all check good. I've heard talk of a "relay". Not sure where to go from here.
Old May 2, 2007 | 08:15 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
Travis , i had the same problem and i got starter from flebay, for 140 and it was reduced gear High TQ starter, it Manhandles the PSD ,,,check them out,
ill see if i can find the link
here it is,
same one i got last year http://cgi.ebay.com/ebaymotors/NEW-F...spagenameZWDVW
and ill tell you , its 2x larger than stock and solenoid is 3x the stock , i cannot be happier than that, great guys and fast shipping
Old May 3, 2007 | 01:34 AM
travis dasher
Yes that is what I meant to say. I unfortunatly had both problems, and it was back to back. When I jumped the truck after installing the first solenoid it started up. Bad solenoid. Replaced the solenoid with a new one jumped the posts again same thing. replaced it with one from Ford and click then it started. My dang starter was going crapping out. Replaced the starter and everything is good now.
Old May 3, 2007 | 01:39 AM
travis dasher
Pete thanks for the link I have it saved in my favs on ebay. I saw that these were for 2000-2001 I wonder if they have them for the 99'. I will wait until the one I have craps out. 2 year warranty from NAPA not bad but expensive. $300.00 without the core charge.
Old May 3, 2007 | 06:16 AM
PETE'S_6.0PSD
its 94-03 so im sure it would fit your truck,
and the story on this one is, when i changed injectors, it looked like i can crank it for 2 min, i did like 30 , 45, sec cranks and dang starter was not worm !!!!!
well im glad you got your truck fixed, to bad i didnt post before in this thread, you could of save 140$ ,,,,sorry Travis,
Old May 3, 2007 | 02:57 PM
travis dasher
No worries. Thanks again for the link it will come in handy. That starter is a monster. Did anyone else have a hard time installing the 3rd bolt on the top of the starter, the one that is right next to the solenoid. That one took me the longest to loosen and tighten. Who designed these things anyways?
corbit96
Sep 16, 2014 06:56 PM
mechelement
40
Jul 28, 2014 02:46 PM
Arizcoin
Apr 7, 2013 08:27 PM
wjjarvis84
Sep 17, 2012 10:22 PM
BigSouth
Feb 15, 2011 03:34 PM
