87-96 sheetmetal compatability
Old Apr 21, 2007 | 09:58 AM
chtulu's Avatar
chtulu
I've got a '91 F-150 SWB 2wd, and it needs some cosmetic upgrades due to various roadside obsticles and what not. My question is-can the front end sheetmetal parts, i.e. fenders, grille, radiator support, bumper, hood, cowl from a 92-96 F-150 be put on my '91? I realize that in the end, it would be just about the same money to go out and buy a 92-96 F-150 and be done with it, but I'm somewhat attached to my '91 and don't want to get rid of it...just "update" it a bit. Also, will the Flareside box off of a 92-96 fit my truck with little to no problems?
Old Apr 21, 2007 | 10:40 AM
'88_F-150's Avatar
'88_F-150
if you change everything over it should all fit but i do not know this for sure
Old Apr 21, 2007 | 12:17 PM
ncranchero's Avatar
ncranchero
Sheet metal will all interchange fine. You'll have to "make" the bumper fit. The mounts are different and due to the rounded 92-96 front the squared 87-91 bumper will look quite odd.
https://www.ford-trucks.com/forums/5...9-chassis.html
https://www.ford-trucks.com/forums/5...onversion.html
Old Apr 21, 2007 | 12:24 PM
chtulu's Avatar
chtulu
I was gonna replace the bumper with a newer one anyways...those damn "roadside obsticles" took their toll on it as well....lol
Old Apr 21, 2007 | 12:26 PM
ncranchero's Avatar
ncranchero
They mount differently. You'll have to fabricate your new mount.
Old Apr 21, 2007 | 12:29 PM
chtulu's Avatar
chtulu
Thanks for the links....saved me a whole bunch of time searching.....I appreciate that.....
Old Apr 21, 2007 | 12:32 PM
ncranchero's Avatar
ncranchero
Look closely at this photo and compare to your bumper mounting to the frame horns. You'll see the difference immediately. The trouble will be worth it !
Old Apr 21, 2007 | 12:41 PM
pud's Avatar
pud
92-96 doors will fit too...theyre slightly different. Along the bottom edge theres a body line thats not on the 80-91 models. The no draft 1/4 windows arent as pointy at the front on the bottom either..
Ive got 92-96/7 door panels on my 90 and they look pretty good in there.
Old Apr 27, 2007 | 01:02 AM
samwe's Avatar
samwe
I just did this, '93 sheetmetal onto a '91.
I found out the panel under the windshield is different.
I also need to get the lights figured out. The '91 has 2 and the '93 sheetmetal needs 4 bulbs!
